I recently replaced the factory stereo in my 57 plate fiesta with a different one after experienceing signal problems. The replacement unit was even worse than that factory one so i changed them back. However since then, my dashboard takes an extremely long time to "boot" i suppose you could say. Obviously there is always a slight lag between turning on the ignition and the needles coming to life, but i can drive 200 yards down the road before any of my needles start registering.
Has anyone else ever experienced this? I dont see how the ISO block on the back of the stereo could be causing this problem? And it's not like the dashboard isn't working at all, it just takes a long time to load.
Thanks in advance.
Any Help? Dashboard Needles Take A Long Time To Load
Started by mattrix, Sep 26 2012 03:00 PM
dashboard stereo needles help radio
2 replies to this topic
#1
Posted 26 September 2012 - 03:00 PM
#2
Posted 10 October 2012 - 02:59 PM
I also have this problem but it is coupled with a weird static/crackling noise :S and some fault codes on the ecu, I havent changed the stereo though
#3
Posted 10 October 2012 - 05:41 PM
First point of call is to check the battery for a good charge and clean connection and then earthing points. That should rule out any basic electrical issues. If it persists then you probably need to visit a dealer or independent with the diagnostic equipment to read out the fault codes and make sense of them.
Also tagged with one or more of these keywords: dashboard, stereo, needles, help, radio
United Kingdom - General Ford Discussions by Model →
Ford Fiesta Club →
Issues Timing My EngineStarted by RDelaCourt, 18 May 2013 |
Ford Fiesta Club →
!!!!!!! Help!!!!!! With Interior Door PanelStarted by D13 HPD 95, 13 May 2013 |
Ford Fiesta Club →
New Fiesta - Radio Not Turning On Automatically?Started by Boggsy, 11 May 2013 |
Ford Fiesta Club →
Poll Fiesta Mk6 Seats Fit Into Mk7?Started by Fast Fiesta, 05 May 2013 |
Ford Fiesta Club →
Help? Automatic Volume Control Mk6Started by pbbyc, 04 May 2013 |
