Retrofit Auto Lights And Wipers
105 replies to this topic
#76 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,133 posts
  • Name: Clive
  • Year: 2015
Posted 15 September 2013 - 03:51 PM
I know there have been issues when people have had damaged windscreens replaced without the silicone spacer and had problems with the sensitivity of the sensors.
I believe the sensor needs the offset from the glass to ensure it detects rain properly.
Have something to contribute?
#77 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
  • Ford Model: Focus Zetec S
Posted 15 September 2013 - 03:57 PM
Right i in that case i need to shop around for the silicone pad since it's a specific size
#78 Stoney871
Stoney871
  • Super Mod
  • 18,133 posts
  • Name: Clive
  • Year: 2015
Posted 15 September 2013 - 05:36 PM
The only one from Ford I could find was listed for the 2011 onwards C-max (code 1720926 £30ish).
I have read on other car sites that a piece of clear sucker cup off an old satnav or phone holder cut to shape/size works ok.
#79 giwrgos_ath
giwrgos_ath
  • Budding Enthusiast
  • 152 posts
  • Name: George
  • Ford Model: Focus MK2.5
Posted 15 September 2013 - 05:48 PM
Kurt, if i were you, i would avoid gluing the mirror. If you need to remove it for whichever reason, you will have huge issues and you might even break the windscreen.
If the cutting did not go well and you cannot alter it to fit, i would recommend to craft something that will slide into position. You can then cut away the remaining part of the mirror base and glue that to the crafted part.
Also, you do need something to hold the sensor in place. Captain Haddock has posted an image of his sensor where you can see how it attaches to the windscreen.
Unless the sensor is attached to the windscreen firmly and there is silicone between the two, you will never get optimal results.
#80 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
Posted 18 September 2013 - 10:18 PM
Thank you gents very much for the info. I did see Captain Haddock photo and assumed i didn't need it. anyways i sourced a new mirror and sensor mount... comes with a sensor too argh...
George i did consider adapting the mirror mount with the standard mirror mount but because of my limited time to work on the car i didn't like the idea of being left without a rear view mirror for any amounts of time.
I will attempt to adapt the mirror for the second time again by cutting it....
How did you fix the mount to the windscreen? the metal plate
And clive i will give the suction cup a try before i purchase any silicone pad
#81 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
Posted 19 September 2013 - 06:51 AM
I haven't glued the metal plate yet. In fact, i haven't finished the whole mod yet. I have tested that it works, but i still haven't been able to source the correct pins to connect the switch with the fusebox.
If anyone can show me the correct type of pins, it would be great. I know which ones i need, but i cannot find an exact match on eBay or RS-online.
Regarding the mirror mount, i  think the old part will not fit easily, so i would create something from scratch rather than use the existing mirror.
#82 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
Posted 21 September 2013 - 02:05 PM
Quick question for you George or anyone else who could answer tbh. Second time round purchasing a mirror, this time i got rather lucky, the mirror came with everything i actually needed.
Sensor + Silicone pad
Mirror with casings and clips
Bonus part: windscreen mount for the mirror
Awesome so i figured no need to adaptor the mirror this time round i only have to glue the mount to the windscreen but then i came across a minor fault! the sensor code is AA not AB like the first sensor i had, that i know works perfectly fine for lights and wipers.
I had a read of the post you've made on this George however it was done before you sorted out the cable needed.
So my question therefore is will be AA sensor work for lights and wipers? i would very much like to know before before i glue anything on because if needs be i can swap over the silicone pad it comes off easily enough but i'd rather not take it off and swap it at all!
Another question, any tips on how to remove the square time mirror mount on the windscreen? not sure yet if it's in the position needed for the round type mount.
This mod is taking an awfully long time for me getting it right is important plus i want it to look factory fitted and professional so no matter how long it takes i will get it done correctly
#83 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
Posted 21 September 2013 - 02:37 PM
Hello Kurt,
I still cannot comment on the -AA or -AB issue. Apparently there is -AC as well. I only tested with an -AB sensor, and i still haven't found the pins needed... :S
Once you activate everything through ELM, you can easily check which one works. Just plug it in (with the engine on ON), and before you position it on the windscreen, cover it to simulate darkness. If the headlights come on, that means that the sensor will be OK to use.
The part of the sensor that attaches to the windscreen is interchangeable. You can easily open the housing using a coin or your keys. Just insert them to the side gaps and twist. If the -AA doesn't work, just put the cover with the silicone on the -AB.
I don't see why the -AA won't work. I compared the electronic parts inside both of them and they look identical. There are different revisions however, which makes me think that they might have different sensitivity levels, or configurations.
#84 JW1982
JW1982
  • 820 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 21 September 2013 - 04:37 PM
The Focus MK2/M2.5 rainsensor with part number 3S7T-17D547-AA is superseded by part number 3S7T-17D547-AB. Part number 3S7T-17D547-AB is superseded by part number 3S7T-17D547-AC.
All of these sensors are basically the same. Based on information from Ford Ecat these sensors are all interchangeable. Part number 3S7T-17D547-AC is the latest version and may have some improvements compared to the earlier part numbers. As far as i can see this sensor is for normal tinted and heated/non heated windscreens.
There is also another sensor for heat reflecting windscreens (these are very rare on a Focus MK2/MK2.5). This sensor has part number 5M5T-17D547-JRB, 5M5T-17D547-JRC or 5M5T-17D547-JRD.
#85 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
Posted 21 September 2013 - 04:43 PM
Hello Kurt,
Excellent reply thanks for the wise words. I will check it and report back, i hope to complete this mod by tomorrow. If lights do not work swapping over the sensor internals it is then, i wasn't aware that was possible.
On the windscreen mount for the mirror that i have, it comes with glass on it lol... i assume the windscreen was destroyed in the removal process, so i've scrapped that idea and i will glue the round type mount directly onto the square type mount, problem self however the downside will be a gap between the cover and windscreen of around 3-4mm, once i have perfected this part i plan to apply a small layer of black (or maybe clear depending on what looks better) silicone all round filling and sealing the gap
A solution to your problem is to get a new connector block, generic ford ones should be fine a exact ford connector block from the dealers should be rather cheap too £3 maybe. From the inside of the connector block (the part that goes into the other connector) where the male pins are you can use a small flat head screw driver to press down the locking leader inside the connector block that will release the pin towards the back, once you have the pin out you can strip the cable pop it into the pin and crimp it together with a pair of pliers (If unable to get a solid crimp, solder it on) then push it back into the connector block.
If you don't already have any blank pins in any of the connectors available, buy the connector block from ford or ebay just the connector alone, this should have all the pins needed.
Ford might even sell the pins by it self although doubtful. There's two different sizes here, from my photo and your photo we can see you've already got the larger cable and in the lower pin, in this case the larger pin should fine.
Male pins http://www.ebay.co.u...=item5d292ae3f3
Female pins http://www.ebay.co.u...=item5d325b53b8
But check ford first because these aren't old parts we're talking about
#86 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
Posted 21 September 2013 - 04:49 PM
Very cool post dude, i will install the AA sensor then and see how well it goes, i had a good enough go using AB so if AB is actually different performance wise i will swap them over once all fitted.
A quick search on ebay i came across this, isn't the correct connector but it has the right pins and you can see the colour coded cable (Red green) in there that's needed for your final part, it has male and female pins
http://www.ebay.co.u...=item3a84bd6fd6
#87 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
Posted 21 September 2013 - 05:29 PM
I need two different sizes of female connectors.
I'm pretty sure rs-online has something that can fit, but i am not very sure how to search for it.
I would like to avoid paying an extreme amount of money for two small part, or destroying a whole loom just to get one cable.
As far as i can tell, those two connector types are used in most wires that originate from the PJB, so it would be nice to have them for reference.
This is definitely the one, but i cannot find anyone selling it. Attached File  7116-4100-02.pdf   262.54KB   110 downloads
The housing of the other connector reads AMP 968705-1 but i'm not sure how to find a pin for it.
#88 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
Posted 21 September 2013 - 06:04 PM
Best bet is to get info from ford mate, if i get the chance to i will pop in and gather some further info. Two female pins required one for the headlight switch connector and one for the PJB connector plus a male pin for this exact female pin shouldn't be hard to find
#89 giwrgos_ath
giwrgos_ath
  • 152 posts
  • Name: George
Posted 21 September 2013 - 06:15 PM
What do you need the male pin for? The male pins exist in all locations. In order to retrofit a wire within a loom, you only need female ones.
#90 mixmasterlooney
mixmasterlooney
    The Sexecutioner
  • PipPipPipPipPip
  • 1,731 posts
  • Name: Kurt
Posted 21 September 2013 - 08:24 PM
I don't need any i was speaking about what you may need if i get round to speaking to ford parts department like i did today
Not what you're looking for?
