Puma
3 replies to this topic
#1 puma1980
puma1980
    Newbie
  • Members via FB
  • Pip
  • 4 posts
  • Ford Model: 1.7 puma
  • Year: 2001
Posted 27 September 2012 - 09:03 AM
When I press brake pedal to stop there is a pulsing through the pedal then sometimes a grinding noise,, what is it? The brakes have been striped and cleaned?
Have something to contribute?
#2 btmaldon
btmaldon
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,581 posts
  • Name: Bruce
  • Ford Model: BMW 320i Coupe M Sport, KA Luxury
Posted 27 September 2012 - 03:40 PM
It sounds like either the discs are warped or your ABS is kicking in. Is this happening at all speeds?
Also when new pads have not been bedded in properly before heavy breaking they overheat and go hard. This can give you a vibration when braking from fairly high speeds such as coming off a dual carriageway onto a slip road and braking for the junction.
#3 puma1980
puma1980
    Newbie
  • Members via FB
  • Pip
  • 4 posts
  • Year: 2001
Posted 28 September 2012 - 11:35 AM
This happens 98% of the time when I use my brake pedal,, i could be doing 10mph and its happens,, car hasnt had new pads or discs
#4 dunny78
dunny78
  • New Member
  • 31 posts
  • Ford Model: Fiesta S1600
Posted 29 September 2012 - 10:54 PM
My mondeo started doing this after having a rear bearing changed. I think it was a dodgy ABS sensor or a bad connection with the plug. It stopped doing it a week before I sold it lol. One way i found to stop it was disconnect one of the ABS sensors. This leaves the ABS light on, on the dashboard and turns the ABS off but should get rid of the pulsing and grinding. If it still does it, it's not an ABS fault and you need to investigate further. Hope that helps
Not what you're looking for?
