Have I Been Robbed
#1
Posted 27 September 2012 - 07:28 PM
#2
Posted 27 September 2012 - 08:03 PM
#3
Posted 27 September 2012 - 08:38 PM
#4
Posted 27 September 2012 - 08:59 PM
Can you explain what the garage claimed to have found? If the wheels are Ford options they should be the correct outer diameter with the approriate tyre. I don't understand what they have charged you for.
#5
Posted 27 September 2012 - 09:26 PM
Silly question but... can anyone do this? Be interested to see if they changed mine when I got it :s
No, only people with a Ford VCM (bit of kit that hooks up to a laptop)
Sam
There are settings for wheel/tyre diameter and size in the configuration parameters for the car (195/50/15, 195/45/16, 205/40/17) Whether this makes the engine compensate for heavier wheels or just adjusts the speedo I do not know.
#6
Posted 27 September 2012 - 09:32 PM
Well all they claim to have changed is the setting you mentioned claiming that was the cause of all my problems and my mpg has risen by 10 mpg up to now the car is more responsive and the engine is silky smooth again so it obviously makes a big differenceNo, only people with a Ford VCM (bit of kit that hooks up to a laptop)
#7
Posted 27 September 2012 - 09:37 PM
My alloys are not ford options they are 17" fox fx004s it had the standard for 16" alloys when i bought it.anyway they claim to have the changed the parameter that tells the car what size wheels/ tyres are fitted to it from 16"-17" an it's made more I a difference than you'd thinkSam
#8
Posted 28 September 2012 - 12:24 PM
Still if your happy then £48 aint bad.
#9
Posted 28 September 2012 - 01:22 PM
Well I'm a bit dubious about what they did but it seems to have helped with my problems bu not quite solved themHmmm.. dubious claims. Heavier wheels won't make that kind of difference and you cannot change the gearing with electronics. If you have 17" rims with 40 section tyres these will give the same diameter as 16" rims with 45 section tyres.
#10
Posted 28 September 2012 - 03:35 PM
You cannot change the gearing but I think you can change the odometer/speedo and trip computer reading to match the tyre diameter. You certainly could on my Saab 900 back in 1995! If Nathan says there is a setting for the tyre/wheel size on the Fiesta then I suspect that is exactly what it does. You can see the different overall wheel diameters using a calculator such as this one: http://www.etyres.co...-calculator.htmHmmm.. dubious claims. Heavier wheels won't make that kind of difference and you cannot change the gearing with electronics. If you have 17" rims with 40 section tyres these will give the same diameter as 16" rims with 45 section tyres.
#11
Posted 28 September 2012 - 07:23 PM
#12
Posted 28 September 2012 - 07:34 PM
#13
Posted 28 September 2012 - 10:16 PM
So would I but they said they only changed to parameter mentioned by Nath and that was it my mpg has jumped from 42 to about 50 hasn't settled yet so it might be going back again yet as it was doing 53 before all this. The confusing thing is I fitted my alloys about 2 months ago and the fault only started last weekMy simple brain can't understand how a 17 inch wheel is different to a 16 inch wheel in any way (other than size and maybe a tiny, tiny bit of resistance for a 205 tyre over a 195) that can affect mpg so much and that could be changed by telling the ECU that you have different wheels. Would be interesting to know what they actually did...
