Bower Posted September 29, 2012 Share Posted September 29, 2012 Hi guys. I got a quick question for you. I was just wondering if putting bigger rims on the car would have effect to what speedometer is showing? i.e. the actual speed, how many miles it does, mpg calculator and etc. The standard rims on fiesta mk7 zetec are 195/50 R15 The new ones would be 205/40/zr17 I know that the tires will fit the car. Simply I dont want to mess with the computer and showings on the clock as the car is new. Thank you in advance! Quote Link to comment Share on other sites More sharing options...
Brigante Posted September 29, 2012 Share Posted September 29, 2012 Hi there Your speedo is calibrated to be out by about 5mph anyway. So when your speedo says you are doing 70mph for example, you will actually be doing about 65mph. You can test this by going by the speed a satnav says. This is so that you don't panic and slam your breaks on when doing say 32 in a 30 zone and you see a speed trap. So instead of going through doing 32 and getting flashed, you'll actually be doing around 28 and not get flashed. So adding bigger rims may just even the speedo out so when it says 70mph you will actually be doing 70mph. It might not even change that much though and might just be around 68mph when the speedo says 70pmh. Hope this helps. I'm sure someone else will be along shortly to advise on the matter further. Quote Link to comment Share on other sites More sharing options...
iNath Posted September 29, 2012 Share Posted September 29, 2012 In a word - yes. Unless you get the car updated with the new size by a Ford mechanic. Going from 195/50/15 to 205/40/17 puts it out by 3.43% so when your speedo shows 70mph you're actually doing 72.4mph http://www.alloywheels.com/Tyre_Calculator Quote Link to comment Share on other sites More sharing options...
2011fiesta Posted September 29, 2012 Share Posted September 29, 2012 As said above yes. Next week I'm getting slightly taller tyres and am going to check the speedo out against my sat nav, and my dads speed read out gadget thingy - if its out by a bit I'll get it booked in with a ford mechanic. Quote Link to comment Share on other sites More sharing options...
Bower Posted September 29, 2012 Author Share Posted September 29, 2012 Thanks for the answers guys! By the way, do you know an answer to this one: if you insure a car with original wheels and then change the rims to custom , would the insurance be void? Quote Link to comment Share on other sites More sharing options...
Brigante Posted September 29, 2012 Share Posted September 29, 2012 You must declare the new rims to the insurance company as they are not the factory fit. Depending on your insurer they may hike up your premium, or they may just charge you an admin charge which is usually around the 15quid mark. If you don't declare them at your own risk, in the event of you being involved in an accident, your insurer can use that you never declared them to wangle they're way out of paying out. Quote Link to comment Share on other sites More sharing options...
iNath Posted September 29, 2012 Share Posted September 29, 2012 As said above yes. Next week I'm getting slightly taller tyres and am going to check the speedo out against my sat nav, and my dads speed read out gadget thingy - if its out by a bit I'll get it booked in with a ford mechanic. Afraid that's not possible - it can only be changed to the set sizes below: Quote Link to comment Share on other sites More sharing options...
2011fiesta Posted September 29, 2012 Share Posted September 29, 2012 Afraid that's not possible - it can only be changed to the set sizes below: Oh, oh dear. I'm getting the same width tire, just slightly taller. So rather than 195/45/16 it'll be somthing like 205/45/16 I think. Quote Link to comment Share on other sites More sharing options...
iNath Posted September 29, 2012 Share Posted September 29, 2012 I'm getting the same width tire, just slightly taller. So rather than 195/45/16 it'll be somthing like 205/45/16 I think. You what? 205 is 10mm wider than 195 silly :P The height is the 45 bit which is a percentage of the width. E.g. 195mm wide, height of 45% = 87.75mm. If you want your size wheels with a higher profile you want 195/50/16, 195/55/16 etc ;) Quote Link to comment Share on other sites More sharing options...
2011fiesta Posted September 29, 2012 Share Posted September 29, 2012 You what? 205 is 10mm wider than 195 silly :P The height is the 45 bit which is a percentage of the width. E.g. 195mm wide, height of 45% = 87.75mm. If you want your size wheels with a higher profile you want 195/50/16, 195/55/16 etc ;) Ok now I'm confused. Thats what I read on here and ordered 195/55/16s - so I went today to get them fitted and the tyre specialists said why have you chose these, you do know its not the middle number that is the height. So for taller tyres you need to move from 195 to say 205. So they're gonna send them back and get me different ones :-s Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 29, 2012 Share Posted September 29, 2012 First number is width, Quote Link to comment Share on other sites More sharing options...
2011fiesta Posted September 29, 2012 Share Posted September 29, 2012 First number is width, *sigh* thats what I thought and said to them - them being the tyre experts I thought I must had misread it. What the hell. ARGHH! Quote Link to comment Share on other sites More sharing options...
iNath Posted September 29, 2012 Share Posted September 29, 2012 *sigh* thats what I thought and said to them - them being the tyre experts I thought I must had misread it. What the hell. ARGHH! Better get back on the phone in the morning! Quote Link to comment Share on other sites More sharing options...
Bower Posted October 3, 2012 Author Share Posted October 3, 2012 Hey guys, I wanted to avoid creating a new topic so will just post here. Picked up my Fiesta from the dealer yesterday ! Yay :D It really does put a massive smile on my face when I look at it :) Probably, because it is my first car... Will upload some pics this evening hopefully! Anyway, my question is about the electric windows : The driver's window does open automatically , i.e. when you press the button once you can release it and it goes all the way down, unless you stop it yourself. While passenger's window , it is still automatic obv, but you have to hold the button and release it whenever you want the window to stop. I would prefer to have passengers window as 'automatic' as the driver's one. I hope this makes sense. I was wondering if it was manufacturing failure or is this just how it works? Thanks for your answers in advance. Quote Link to comment Share on other sites More sharing options...
iNath Posted October 3, 2012 Share Posted October 3, 2012 That's just how it works I'm afraid, one-touch up/down is only on the drivers side. Think yourself lucky, in the new Focus you only get one-touch down, they have to hold it to go back up! Quote Link to comment Share on other sites More sharing options...
jmbrown91 Posted October 3, 2012 Share Posted October 3, 2012 That's just how it works I'm afraid, one-touch up/down is only on the drivers side. Think yourself lucky, in the new Focus you only get one-touch down, they have to hold it to go back up! Now that is ridiculous... Quote Link to comment Share on other sites More sharing options...
Bower Posted October 3, 2012 Author Share Posted October 3, 2012 Thanks Nath! I promise to start a new topic this evening! :D In the meantime, another quick q: Has any of you tried changing pedals? I mean something like this : http://www.ebay.co.u...5#ht_3937wt_952 Is it worth doing that? Do those fit well and not wobble around? I probably would not want to spend 25+ quid on sparco pedals so I was just wondering what you guys think about it? Also, I am trying to make up my mind between these two types of footwell mats: http://www.ebay.co.u...#ht_1102wt_1139 http://www.ebay.co.u...6e#ht_678wt_952 I am not sure if the second one are suede-type mats or just rubber though. I am a bit afraid that the interior will end up being like a Coca-Cola Christmas tree if I buy the red mats as well. ( I have ordered red bulbs for footwell already) Thoughts are welcomed and much appreciated! Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 3, 2012 Share Posted October 3, 2012 There is a possibility of making any electric window one touch opening but you would have to source the same relay as connected to the drivers side and splice it into the passenger side loom. Research on the web may well pull up the info needed. Quote Link to comment Share on other sites More sharing options...
iNath Posted October 3, 2012 Share Posted October 3, 2012 Thanks Nath! I promise to start a new topic this evening! :D In the meantime, another quick q: Has any of you tried changing pedals? I mean something like this : http://www.ebay.co.u...5#ht_3937wt_952 Is it worth doing that? Do those fit well and not wobble around? I probably would not want to spend 25+ quid on sparco pedals so I was just wondering what you guys think about it? Spend some money and get the proper set :) http://www.ebay.co.uk/itm/Genuine-Ford-Fiesta-Aluminium-Alloy-Pedal-Set-2008-Onwards-/200816204399?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ec1941a6f&_uhb=1#ht_1449wt_1074 Quote Link to comment Share on other sites More sharing options...
jimrex Posted October 4, 2012 Share Posted October 4, 2012 Now that is ridiculous... Yup! The thing I hate most about that car. I would swap one touch down for one touch up... Quote Link to comment Share on other sites More sharing options...
