trev16185 Posted October 2, 2012 Share Posted October 2, 2012 Hi I'm looking for opinions and Info here.. I have a 2005 tdci mondeo 2.0 130bhp euro 4... I have noticed that when pulling away this is a sign of what looks like black smoke from exhaust.. Also I noticed that if car is left at idle for approx ten mins or so when you then pull away the black smoke is more of a cloud.. The smoke seems to clear once you get up the rpm's Quote Link to comment Share on other sites More sharing options...
mintalkin Posted October 3, 2012 Share Posted October 3, 2012 check the intercooler pipe for splits(its the large pipe on the bottom of the egr valve) also when was the egr valve itself last removed and cleaned ? Quote Link to comment Share on other sites More sharing options...
DaveD Posted October 3, 2012 Share Posted October 3, 2012 Uh oh MOT fail coming up. Quote Link to comment Share on other sites More sharing options...
trev16185 Posted October 6, 2012 Author Share Posted October 6, 2012 Hi guys thanks for replys.. Intercooler hoses seem fine I checked them visually an also while holding a rev on the car the pipes all become firm with no signs of leaks.. But I seem to keep get the fault codes P0401 and p0405 poppin up.. When clear car will drive a few miles without light then after sits turned of for approx ten mins and started again light appears..(engine light).. I have since tried a new egr valve to no affect.. Any ideas what this is.. The black smoke seems to have calmed itself.. My train of thought is more why is these 2 codes re appearing... P0405 says... Exhaust gas recirculation sensors A circuit low P0401 says..exhaust gas recirculation flow insufficient detected... Driving me mad... :-( Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 6, 2012 Share Posted October 6, 2012 Did you replace the EGR sensor or check the wiring? Quote Link to comment Share on other sites More sharing options...
trev16185 Posted October 6, 2012 Author Share Posted October 6, 2012 Yes replaced egr but no difference..I wouldn't know what values to be looking for at the egr 3 pin plug.. Would it be possible the maf sensor is faulty Quote Link to comment Share on other sites More sharing options...
trev16185 Posted October 6, 2012 Author Share Posted October 6, 2012 Ok just tested sensor in both old n new egr valves both read 1.5 volts closed and 4.5 volts open.. Is there something I'm missing that's causing this fault... Really drivin me mad Quote Link to comment Share on other sites More sharing options...
glyndwr Posted October 14, 2012 Share Posted October 14, 2012 hi iv just put an egr blank plate in and stopped all smoke ,, now getting better acceleration and better fuel economy Quote Link to comment Share on other sites More sharing options...
trev16185 Posted October 16, 2012 Author Share Posted October 16, 2012 If u blank egr does this not leave engine check light on all the time on euro 4.?. I had my vacum regulator go faulty which gives same effect as blanking egr and light stayed on Quote Link to comment Share on other sites More sharing options...
