Sign in to follow this
KatePocket
Squeeky Acceleration
Hiya,
I've noticed that my clutch (i think its my clutch) seems to squeek on acceleration when i am travelling fast (on motorway/dual carriageway) its almost like a wheel spin sound, but thats not what it is.
Any ideas?
Your clutch squeaks on acceleration when you are travelling fast?!
Sorry, i didn't really explain that very when, when i change gear and come off the clutch the clutch seems to squeek, it might just be that it needs a bit of oil on it but i wanted to check incase it might be something else that is a common problem.
could be the clutch release bearing ,does it stop if you put your foot under the clutch pedal and lift it up slightly ? used to be a fault on the 95 to 2001 models
Its more likely to be the clutch pedal return spring. Common for them to squeak on the focus too.
My mk 6 clutch squeaked, and my new mk 7 does too, on the courtesy check they said they'd fixed it but they hadn't.
Same on mine, only tends to squeak when the weather is very cold.
Any ideas?
Are you sure it's not the belts that's slipping(alternator,fan belts,etc..)? Very common and sounds similar to a screeching tire. A faulty belt roller/tensioner squeaks too!
