zahtar Posted March 22, 2014 Author Share Posted March 22, 2014 negendahl, If you can't find a matching set, you can also spray paint them yourself if you happen to have colour coded paint. Just make sure you do this before installing them. This is not ok for every set of sensors so make sure you buy those that can be painted. I did mine with the touch up kit and from up close they do look a bit sloppy, but from 1m (3ft?) away they look ok. Quote Link to comment Share on other sites More sharing options...
negendahl Posted March 22, 2014 Share Posted March 22, 2014 negendahl, If you can't find a matching set, you can also spray paint them yourself if you happen to have colour coded paint. Just make sure you do this before installing them. This is not ok for every set of sensors so make sure you buy those that can be painted. I did mine with the touch up kit and from up close they do look a bit sloppy, but from 1m (3ft?) away they look ok. I'll look into it, thanks for the reply! Sent from my Nexus 5 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
M4RC Posted March 27, 2014 Share Posted March 27, 2014 Defo gonna get a set of these, just wondering is there two layers too drill through? Also does anyone know the factory dimensions? Quote Link to comment Share on other sites More sharing options...
M4RC Posted April 4, 2014 Share Posted April 4, 2014 Anyone know the best measurements? Quote Link to comment Share on other sites More sharing options...
zahtar Posted April 20, 2014 Author Share Posted April 20, 2014 No it is just one layer of plastic to drill through, the painted part of the bumper. The dimensions I mentioned in step1, are the safest regarding the car. A technician from an authorised ford service center recommended them. But make sure they comply with the manufacturer of the sensors. Some recommend lower drilling height so you won't lose low obstacles. This is both for safety reasons as well as for functional. If you install them lower than the manufacturer suggests, they might give false posisive detection every time you reverse. And I am sure you don't want that ;) Quote Link to comment Share on other sites More sharing options...
M4RC Posted April 20, 2014 Share Posted April 20, 2014 No it is just one layer of plastic to drill through, the painted part of the bumper. The dimensions I mentioned in step1, are the safest regarding the car. A technician from an authorised ford service center recommended them. But make sure they comply with the manufacturer of the sensors. Some recommend lower drilling height so you won't lose low obstacles. This is both for safety reasons as well as for functional. If you install them lower than the manufacturer suggests, they might give false posisive detection every time you reverse. And I am sure you don't want that ;) It's all good, I got them done mate :)For some reason I can't put a pic up but have a look in the link in my bio thing (just below :) ) Quote Link to comment Share on other sites More sharing options...
zahtar Posted April 20, 2014 Author Share Posted April 20, 2014 Glad it worked out mate! Can't see the pic from the mobile, when back home I'll check it out. Enjoy! Quote Link to comment Share on other sites More sharing options...
negendahl Posted April 23, 2014 Share Posted April 23, 2014 I know it seems cheap.. but i was looking at this http://www.aliexpress.com/item/freeshipping-auto-electromagnetic-parking-sensor-no-holes-need-easy-install-parking-radar-Bumper-guard-back-up/395189211.html Just ordered one, not too much money wasted if it does not work, mostly work hours. But not to sure about quality for that kind of money! :D Quote Link to comment Share on other sites More sharing options...
zahtar Posted April 24, 2014 Author Share Posted April 24, 2014 M4rc, they look fine mate! Negendahl, I had heard of these, but was doubtful. Good thing that you don’t need to drill the bumper, but plz let us know how detection works ;) Quote Link to comment Share on other sites More sharing options...
negendahl Posted April 30, 2014 Share Posted April 30, 2014 Will do! Currently waiting shipment from China. Sent from my Nexus 5 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
negendahl Posted May 14, 2014 Share Posted May 14, 2014 I received the parking sensor, looks alright. I will try to install it soon. Quote Link to comment Share on other sites More sharing options...
zahtar Posted May 15, 2014 Author Share Posted May 15, 2014 good to know! keep in mind that you might need to do a bit of spot cleaning since the EM tape is adhesive (see the pics of step 3). let us know about its responsiveness. good luck! Quote Link to comment Share on other sites More sharing options...
negendahl Posted May 15, 2014 Share Posted May 15, 2014 good to know! keep in mind that you might need to do a bit of spot cleaning since the EM tape is adhesive (see the pics of step 3). let us know about its responsiveness. good luck! Yeah, my plan was to remove the bumper, clean it, and then install - maybe give it some duct tape on the back just to make sure it holds. Will install on Thursday, need my dad's help for something else on the car, he is a mechanic, so i will be able to get it on the lift. Looking forward :) /Mick Quote Link to comment Share on other sites More sharing options...
negendahl Posted May 18, 2014 Share Posted May 18, 2014 Decided to do it yesterday, sun was out - lovely! :) Took off the bumper (following this: )Gave the surface a good cleaning, stripe on and then some duct tape over it to hold / keep dirt out, then i did all the wireing, mounted back on the bumper. Took me a good 2 hours (with some help from my girlfriend, turns out she had fun "fixing the car" with me :D) Tested and works, so so far I'm a happy man :) Quote Link to comment Share on other sites More sharing options...
SeanW Posted May 18, 2014 Share Posted May 18, 2014 Decided to do it yesterday, sun was out - lovely! :) Took off the bumper (following this: http://www.youtube.com/watch?v=Rq5wTSly488) Gave the surface a good cleaning, stripe on and then some duct tape over it to hold / keep dirt out, then i did all the wireing, mounted back on the bumper. Took me a good 2 hours (with some help from my girlfriend, turns out she had fun "fixing the car" with me :D) Tested and works, so so far I'm a happy man :) Has she got a sister? Sent from my GT-I9300 using Ford OC mobile app 1 Quote Link to comment Share on other sites More sharing options...
zahtar Posted June 1, 2014 Author Share Posted June 1, 2014 good to hear it turned out nice mate! And a really good thing your gf had fun helping with the car!!! enjoy! Quote Link to comment Share on other sites More sharing options...
negendahl Posted June 16, 2014 Share Posted June 16, 2014 Hmm..seems like it have stopped working - i just came back from the town yesterday, and when i put the car in reverse it just constantly beeps - like something is right behind it. Haven't looked more into it as i was a bit busy - just an update :) Quote Link to comment Share on other sites More sharing options...
alexandjen Posted June 16, 2014 Share Posted June 16, 2014 Hmm..seems like it have stopped working - i just came back from the town yesterday, and when i put the car in reverse it just constantly beeps - like something is right behind it. Haven't looked more into it as i was a bit busy - just an update :) Perhaps the duck tape has peeled off tricking the sensor into thinking an obstruction is present Quote Link to comment Share on other sites More sharing options...
negendahl Posted June 16, 2014 Share Posted June 16, 2014 Perhaps the duck tape has peeled off tricking the sensor into thinking an obstruction is present Sounds like a possible explanation :) I will check it out during the week, thanks. Quote Link to comment Share on other sites More sharing options...
zahtar Posted June 16, 2014 Author Share Posted June 16, 2014 That's exactly what I guessed of too! Keep us posted mate, good luck! 1 Quote Link to comment Share on other sites More sharing options...
SeanW Posted June 16, 2014 Share Posted June 16, 2014 Might just need a quick wipe over. Mine do that occasionally because of dirt Sent from my GT-I9300 using Ford OC mobile app 1 Quote Link to comment Share on other sites More sharing options...
negendahl Posted June 16, 2014 Share Posted June 16, 2014 Might just need a quick wipe over. Mine do that occasionally because of dirt Sent from my GT-I9300 using Ford OC mobile app Could be, it is pretty dirty and will get a wash soon :-) will be in touch Sent from my Nexus 5 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
zahtar Posted June 16, 2014 Author Share Posted June 16, 2014 It has happened to me as well with dirt. I painted mine with a brush (not paint) and got it too thick on a sensor. When it got dirty it happened to give false positive detections. That happened with rain drops too! The solution was scratching a bit of the clearcoat of the specific sensor and now it works fine. If your set is more sensitive to make it work through the bumper (detection distances imply it is) then a dirty bumper could justify the false detection. At least in my opinion... Quote Link to comment Share on other sites More sharing options...
negendahl Posted June 16, 2014 Share Posted June 16, 2014 Lol.. Looked closer found a pice of dried out bird crap, took it off then it seemed to work. Hope that was the problem. I couldn't see any of the tape had loosent, so that was not the problem Sent from my Nexus 5 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
zahtar Posted June 17, 2014 Author Share Posted June 17, 2014 Hmmm, it seems bird poo can cause more issues than etching on the paintwork :) good to know its back up and running! sent from my foolphone using tapatalk! xD 1 Quote Link to comment Share on other sites More sharing options...
