jamesabell22 Posted October 10, 2012 Share Posted October 10, 2012 I have recently purchased a Ford Focus 1.4 CL (1999) T Reg. The car has manual central locking, although i would like to know if it is possible to adapt the car for remote central locking? Would be grateful if i could receive some help on whether i can do this, what i need for it and how much it would likely cost? Quote Link to comment Share on other sites More sharing options...
dezwez Posted October 10, 2012 Share Posted October 10, 2012 remote central locking is not on the cl bace model you could try a aftermarket one off eBay hope this helps Quote Link to comment Share on other sites More sharing options...
jamesabell22 Posted October 10, 2012 Author Share Posted October 10, 2012 Ive found this on eBay which is an official module, It states my car is compatible? Would you agree? http://cgi.ebay.co.u...E:X:AAQ:GB:1123 and http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160746376367&ssPageName=ADME:X:AAQ:GB:1123 Quote Link to comment Share on other sites More sharing options...
dezwez Posted October 10, 2012 Share Posted October 10, 2012 it would have to be programed by main dealer and i dont think your car would have all the wiring fitted for it to work Quote Link to comment Share on other sites More sharing options...
dezwez Posted October 10, 2012 Share Posted October 10, 2012 the cheapest way would be this on e bay item number: 170922897650 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted October 10, 2012 Share Posted October 10, 2012 you have to remove the doorcards to check if the wiring is there some have it some dont then you require the modules then you require a remote fob that needs coded which can be done manualy all in a few hundred pounds easier to buy an aftermarket alarm with central locking facility and more reliable Quote Link to comment Share on other sites More sharing options...
jamesabell22 Posted October 10, 2012 Author Share Posted October 10, 2012 Thank you i will take a look at that! Quote Link to comment Share on other sites More sharing options...
artscot79 Posted October 10, 2012 Share Posted October 10, 2012 just beware when removing the foam seal behind the door panel dont tear it as its all that keeps the water out the car and its stuck down with a pliable seal it requires a sharp stanley blade and patience as you cut the seal at the edges seperating the panel Quote Link to comment Share on other sites More sharing options...
