key fob pats prgramming problem
30 replies to this topic
#31 drewtiss
drewtiss
  • New Member
  • 38 posts
  • Ford Model: Ford Focus
Posted 19 March 2009 - 08:15 AM
I have just bought a second hand fob from ebay it doesn't have a new key blank as yet, its just the remote fob. I have sucessfully programmed the fob so that it can open and lock the doors remotely from the fob.
The problem I am having is I can't get the fob to start the engine with the existing key shaft from another key that is already paired.
I have followed the instructions of using two existing paired keys and putting them in one by one switching from 0 to II on the ignition to get me into the pats programming mode. As I am only holding the remote key fobs onto the key shaft it allows me to quickly swap the paired key fob over with the one I bought off ebay. I turn this from position 0 to II and remove the key.
Then I wait a while and try the new fob, it starts the engine, but it takes a few seconds longer than the working key would normally take to start the engine, but it does start the engine eventually.
The problem I am facing is that the key from eBay will only start the engine ONCE after I have run the pats programming procedure. After that it fails to start the engine anymore.
I then read about erasing all other keys apart from the original mercedes benz parts paired two, so I tried that hoping that the car already had known keys to it and it wasn't allowing the new key to be paired.
I ran the procedure in the book for erasing the other keys, then I re-ran the pats programming to pair the ebay key but I'm still having the same issue, the key will only ever start the car ONCE!
Any idea what I might be doing wrong or what could be the problem?
Your help would be very welcomed.
Thanks. (sorry for the long post!
I have this problem long time ago. I even ask my uncle about his programming skills but none of them helped me.
Have something to contribute?
Not what you're looking for?
