Got a problem with my Ford Focus 1.6 mk2 2005 on a 55 plate currently @ 77k miles full service history, I have recently had coil pack just the pack changed. and power steering as that went on me aswell. I have noticed now that there is OIL sitting in the spark plug area??? surely there shouldnt be oil sitting where the spark plugs sit? Help is this serious problem? also when I had a power steering leak a noise from i dont know where is now there a whine when i sit ideling or when i press the gas pedel no idea what it is. so need a little help ?????????//
Ford Focus Mk2 2005 1.6 Petrol Oil In Spark Plugs Area
#1
Posted 23 October 2012 - 11:34 PM
#2
Posted 24 October 2012 - 11:29 AM
#3
Posted 25 October 2012 - 02:58 AM
The oil is most likely leaking from the camshaft cover. The gasket probably needs replacing. As far as the whining noise goes, it sounds like it could either be your power steering pump or the cambelt pully.
Is this a expensive job to get repaired if its the gasket that needs replaced?
Posted 25 October 2012 - 02:59 AM
#5
Posted 25 October 2012 - 09:39 AM
#6
Posted 25 October 2012 - 10:00 AM
its not an expensive job to have the gasket replaced a garage should do it in 30-40 minutes including cleaning up all the oil it wont damage the car but it may well be the reason for the coil pack failure
Thanks for that bud - so roughly how much do you think the repair would cost? would I need new spark plugs as oil is sitting around them where the spark plugs go?? ( I know nothing bout car just drive them lol ) clueless here hahah.
The car fails to start at times aswell but its a new coil pack bosch one fitted less than 2 weeks ago.
#7
Posted 31 October 2012 - 10:19 PM
£13.50 and its getting fitted soon, I have soaked up the oil using blue roll and aalso bought new spark plugs aswell.
#8
Posted 01 November 2012 - 02:25 PM
#9
Posted 04 November 2012 - 03:08 PM
#10
Posted 05 November 2012 - 10:30 PM
good job when fitting the gasket its best to use a little water pump or gasket seal on it apply some to the rocker cover then fit the gasket then apply to the head whare the gasket will sit and fit
had the job done tonight - cam cover taken off to find loads off oil in the spark plug chamber n spark plugs soaked in oil.
new gasket seal fitted n put back together and still leaking oil taken off again this time applying bond sealer to it when in place holding the gasket seal in place which seems to do the job nicely now. without using any sealer cam gasket cover falls out. 4 new spark plugs fitted aswell
Also tagged with one or more of these keywords: FORD FOCUS, OIL, SPARK PLUGS
United Kingdom - General Ford Discussions by Model →
Ford Focus Club →
Ford Focus Mk2 Facelift 2010Started by TeeJay22, 23 May 2013 |
General Forums →
Maintenance →
Focus 2.0 Tdci Intermittent Starting IssueStarted by RobK, 29 Apr 2013 |
Ford Focus Club →
Urgent Advice - 2003 1.8 Tdci Zetec Scrap Or SaveStarted by Misery, 26 Apr 2013 |
Ford Focus Club →
Focus 2005/ 1.8 Tdci Servicing - Info / Advice NeededStarted by glennkelly, 18 Apr 2013 |
General Forums →
Servicing / MOT Discussions →
Auto Electricians In The Newcastle Upon Tyne AreaStarted by favero, 16 Apr 2013 |
