What Is This Part Called ?????????
9 replies to this topic
#1 jimmygixer
jimmygixer
  • Budding Enthusiast
  • 103 posts
  • Ford Model: Focus sport TDCi
Posted 25 October 2012 - 03:20 PM
This car is driving me mad, where is this !Removed! water coming from. :wacko:
Can anyone tell me what this part is, passenger side floor, at right foot side center of focus?
I have had my carpet pulled back for weeks now, thought i had the leak fixed with a bit of silicone when i sealed this part at the top left corner where the condensation seemed to be coming from.
Still water and condensation sitting around this part
Have something to contribute?
#2 Lenny
    Retired Moderator
  • 11,366 posts
Posted 25 October 2012 - 03:31 PM
Welcome to the forum,
It seems your pollen filter housing is leaking.
May i recommend a new pollen filter and housing seal. Its a common problem on the focus
#3 jimmygixer
jimmygixer
  • 103 posts
Posted 26 October 2012 - 01:22 AM
Its definitely not the pollen filter housing as i have checked and fully resealed all that area and tested with a hose.
Its leaking around the evaporator housing i believe its called.
#4 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,927 posts
  • Name: arthur
  • Year: 2006
Posted 26 October 2012 - 08:12 AM
it seems it may be the heater matrix or an aircon leak maybe even a loose aircon pipe or the dryer has gone and its not removing moisture from the air it shouldnt be leaking there (obviously) you may need to take it in to fords to get a leak check done im being honest ive never seen a leak from that area mate its possible its coming from elsewhere but falling above that area and running down
#5 jimmygixer
jimmygixer
  • 103 posts
Posted 26 October 2012 - 12:15 PM
Because of where its at, visibility and access isnt great, but from feeling the carpet that runs up the firewall, the dampness stops at the top of the part shown in the picture. Since i put a bit of sealant around the top edge of the join of the box, the water seems to have changed direction of running down the floor. Its not a instant leak and it is slow enough so its hard to trace.
Its a weird one because ive had the car being dry for a few days and then suddenly it will come back, and thats even when the weathers been dry.
The aircon is running 100% and im not losing any coolant.
Is there any other points of entry above this part which you know about except for the pollen filter?
Cheers
#6 artscot79
artscot79
  • PipPipPipPipPip
  • 7,927 posts
  • Name: arthur
  • Year: 2006
Posted 26 October 2012 - 12:52 PM
not on the mk1 windscreen would be 1 other than that as you say its been dry so its not rain i can only assume the aircon drain on the drivers side is blocked up the pipe and its gathering and running out
#7 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,093 posts
  • Name: Clive
  • Year: 2015
Posted 26 October 2012 - 09:56 PM
Agreed, most likely aircon condensation.
#8 jimmygixer
jimmygixer
  • 103 posts
Posted 27 October 2012 - 02:21 AM
Anyone know of the easiest way to get at the evaporator box to seal right round it without removing the hole dash?
#9 artscot79
artscot79
  • PipPipPipPipPip
  • 7,927 posts
  • Name: arthur
  • Year: 2006
Posted 27 October 2012 - 10:00 AM
you need to find the aircon drain on the drivers side and make sure its fully open as im sure its blocked up the pipe aircon condensation shouldnt be coming out the joins in the box sealing it is a waste of time as the water will just find another way to get out you must fix the issue before you can cure it and no the entire dash would have to come out which is around a 6 hour job just to get it out
#10 jimmygixer
jimmygixer
  • 103 posts
Posted 27 October 2012 - 05:27 PM
I take it there is only 1 drain?
The one i checked was dripping water as it should but i blew it out anyway with an airline. It had a bit of rubber hose in a u bend shape connected to it, to keep dirt out and the water from running back onto the firewall.
But this was in the middle of the car, if not closer to the passenger side?
Not what you're looking for?
