KillSwitch Posted October 26, 2012 Share Posted October 26, 2012 Hi guys, i got FOB uncoded and a new blade cut, i have 2 other keys coded to my car that i used to try and code this new FOB key, when u do the coding bit and put the new key in to be coded it does not code right, it will start the engine ( the red light still stays on ) untill u take the key out then it dont work agen, but it opens and closes the doors. ( not remotely ) i dont understand whats going wrong, if it was not coding AT ALL surely it wouldnt even start the engine ? shes a "2003 Fiesta Finesse" Quote Link to comment Share on other sites More sharing options...
Musketter Posted October 26, 2012 Share Posted October 26, 2012 I might be wrong, but I thought the procedure to code the remote does just that. It doesn't code the imbolizer chip built into the key. What I beleive is happening is that you are putting the old key in and turning the ignition on, then inserting the new key and coding the remote. The imobilzer will stay "live" for a short while (Around 2 minutes on my old Pug!), then cut off. This is why it works at first but then packs up. Hope it helps Quote Link to comment Share on other sites More sharing options...
Dan62 Posted October 28, 2012 Share Posted October 28, 2012 \ Quote Link to comment Share on other sites More sharing options...
KillSwitch Posted October 28, 2012 Author Share Posted October 28, 2012 yea i got the right key and got it got cut right Quote Link to comment Share on other sites More sharing options...
Dan62 Posted October 29, 2012 Share Posted October 29, 2012 \ Quote Link to comment Share on other sites More sharing options...
