fiesta oil leak
#1
Posted 25 February 2009 - 07:53 PM
1996 1.3 fiesta started losing power on a recent journey and ended up towing it 30 miles. chabged head gasket to no avail,someone suggested a blockage in the exhaust so i tried that and pulled out a great chunk of carbon looking stuff from the cat. hey presto the power was back and car running fine. drove to bradford from bridlington with no problems apart from a slight oil leak from sump. got a new sump gasket fitted,but then leak seemed to move to the rocker gasket and got worse. seems to be pressurising somewhere does anyone have any ideas.
#2
Posted 25 February 2009 - 09:29 PM
I think the rocker cover gasket gets change every 4th service or so. There not expensive and real easy to fit. Take the plug leads of and put them out your way. Then just 4 screws holds it on.
Sometimes the gasket can be 'baked on' its a real nightmare to get it all off. You might as well give it a good clean while your there.
#3
Posted 25 February 2009 - 09:34 PM
Maybe you just didn't notice the rocker cover leaking before? The old endura 1.3's are good at leaking oil.
just replaced rocker cover last week when i did head gasket and it wasnt leaking then???
#4
Posted 25 February 2009 - 09:38 PM
#5
Posted 25 February 2009 - 09:42 PM
#6
Posted 25 February 2009 - 10:05 PM
Check your crank vent filter cap. Could be blocked...
#7
Posted 25 February 2009 - 10:14 PM
#8
Posted 25 February 2009 - 10:21 PM
I have a mk5 fiesta with the same engine up at my unit. Will have a look for you but am not going back up till sat.
#9
Posted 25 February 2009 - 10:23 PM
Latest Comments
More
