Ice Upgrades
ICE stereo amplifier subwoofe
172 replies to this topic
#151 Hassen
Hassen
  • 1,097 posts
  • Name: Hassen
Posted 01 July 2013 - 09:38 PM
I certainly will as I have half of the electronics already to make it sound fantastic. As I said earlier, though, I intend to live with the factory Nav system until it gets me lost a few times because it actually sounds very good. Also, the nav instructions and radio info are displayed where the dials show - it's a good setup.
Speakers wise, I would go with focal again I think. I have always loved Blaupunkt gear, just never tried their speakers/amps in my cars, yet.
That's cool that it displays where the dials show. Reckon speaker wise whatever sounds good to your ears is the one to go for, budget allowing of course:)
So far liking the Blaupunkt amp even though it's a bit of an older amp and was second hand.
You have a crossover built into your head unit? - if you left it "flat" and used the crossover in the amp, the amp would reject noise below the crossover frequency, reducing hum.
Apart from increasing the power handling of the front speakers, increasing the srossover frequency above 100Hz can help reduce intermodulation distortion, the typical bass note or kick drum will have elements above 100Hz, this means bass notes will be spread between the sub and the front speakers, which may cause phase distortion, raising the frequency so that the sub handles kick drums/ bass notes should give you tighter bass, and overall sound, phase alignment would help, too, of course, this is all theoretical and its what sounds good to your ears/ and to your taste
Not sure if there is a cross over in the Pioneer AVH 2500BT for the front speakers. Still getting used to all the settings for it. Spent 1/2hr today playing different types of music and playing around with the settings off the amp and the head unit. There is still a bit of hum but no distortion coming from the front speakers any more. There was a tiny bit before especially on a track like Daft Punk - Around the World, coming from the front speakers. At the moment, I sound the music is to my liking but I will keep re-adjusting the parameters till I am perfectly happy. I think I might have done what you mentioned by total fluke without knowing the theory behind it lol.
It is most important to separate the power cables from the rca cables. This is because any hum will be multiplied through the amplifier. Speaker cables will not have this problem. Turning down level on the amplifier is good, as is having solid earthing on both head unit and amplifier.
Pioneer head units are known for blowing their earth fuses - located inside the head unit. This can happen if you have bad earthing connection on the amplifier and large current will flow through the rca cables - blowing this fuse. This will result in alternator noise in the speakers.
This link is showing a cheap fix:
http://bcae1.com/ima...ieldrepair.html
You can try if this is your problem - by just only for a moment connect a ground cable to the shielding - to check if the noise disappears.
Edit: Trying a good quality, well shielded rca signal cable could be worth it.
At the moment, the RCA cable from the head unit to the amp in the boot is running fairly close to the power cable for the amp. I reckon that this might be the cause for the hum. I tried relocating the speaker wire during the weekend but no luck. At present, the power cable, speaker cable for the left front speaker, remote wire for the amp and rca cable for the front speakers are all running on the left side of the car, near the door sills.
Any ideas on a good placement to relocate the power cable or RCA cable without too much hassle. Found out that I couldn't find a spot to pass the RCA cable from the head unit, onto the right hand side of the car and all the way back to the amp in the boot.
I was also thinking of getting a set of Vibe Black Air 6 component speakers for the front of the car.At the moment, I only have one amp (Blaupunkt GTA 470) that is powering the front Vibe 6 Slick speakers and the 10 inch sub. If I were to get the component speakers, will I need 2 channels ''Front and Rear inputs'' to power the woofers and the tweeters separately or can I just use the ''Front input'' that will then feed into the cross over which then wires to the woofer and tweeters with that input set to ''Flat'' ? I hope I am making myself clear and my apologies for being an ICE noob. Found a 2nd hand set of these speakers and very tempted to get them and move the Vibe 6 Slick to the back of the car, just powered by the factory wiring present. Reckon that might give the sound stage a bit more dimension and quality.
Thoughts?
Have something to contribute?
#152 cragger89
cragger89
  • Budding Enthusiast
  • 77 posts
  • Name: Craig
  • Ford Model: Mk3 Mondeo Ghia, 2.0l
  • Year: 2006
Posted 02 July 2013 - 10:55 AM
no - component speakers do not need additional amplification.
#153 Hassen
Hassen
  • 1,097 posts
  • Name: Hassen
Posted 02 July 2013 - 07:45 PM
I would rather connect them to the amp as it would get the best out of the speaker/tweeters I feel. Please do correct me if I am wrong. Also, I found the way to do it online. I was a bit confused with the right and left wiring and now know how to wire it all.
Anyone else has any recommendations for a set of component speakers for the front? Around the £100 mark for the set
#154 Mr_Spock
Mr_Spock
  • 83 posts
  • Name: Tom
  • Ford Model: Ford Focus 1.6 Petrol Hatch
  • Year: 2005
Posted 02 July 2013 - 08:19 PM
Yes, using the amplifier for the front components speakers would be the best solution. Speaker cable from the amplifier to the crossover - where it splits in to a speaker cable to woofer and a speaker cable to the tweeter. Where to put the crossover will depend on where you mount the tweeter - in the door or on the dash. You will use the head unit directly to the speakers in the back doors? Could maybe be difficult to adjust the sound level between the front speakers, subwoofer and the back door speakers - but could work.
These are a great component set:
http://www.amazon.co...words=focal 6.5
But you will probably get different suggestions depending who you ask :) Read some tests - and maybe look for a good set that are on sale?
#155 Hassen
Hassen
  • 1,097 posts
  • Name: Hassen
Posted 02 July 2013 - 11:47 PM
That's what I was thinking of doing and as for the rear speakers, just leave them connected to the stock wiring found in the car. Front speakers powered by amp and rear just coming off the head unit. I reckon there might be a difference in sound levels, but I can fade them from the head unit front/rear to my liking.
From just a quick read through reviews online, those Focal component speakers seem to be something I might be interested in. More research needed since there are no Focal dealers here and need to find others who have it.
Anyone around who got the Focal speakers? Would like to hear your personal experience with them
#156 cragger89
cragger89
  • 77 posts
  • Name: Craig
  • Year: 2006
Posted 03 July 2013 - 10:21 AM
Apologies, I thought you meant amplifying the tweeters and the mid drivers independently!! (one amp for the mid drivers, one amp for the tweeters = biamping)
All speakers, components/coaxials will benefit from being amplified by a separate amp. This is the configuration I referred to in my original long post. Use the front side of the amplifier for the front speakers, fed by the front pre outputs from the head unit. Then use the rear side of the amplifier for the subwoofer.
#157 Hassen
Hassen
  • 1,097 posts
  • Name: Hassen
Posted 03 July 2013 - 01:47 PM
Cool. That's how I am thinking of doing it after getting the front component speakers. Thanks :)
So far, after reading a bit about these speakers and Focal as a company, liking a lot what I have heard. These are not their high end speakers but seems to be very reasonable in price and give a good sound quality once amped.
Annoying bit is that most places are charging ridiculous money for it to be delivered to Ireland (£20-30!). I have find a place where it's either cheaper posting or free.
Suggestions welcomed. Destination country, Republic of Ireland
#158 Mr_Spock
Mr_Spock
  • 83 posts
  • Name: Tom
  • Year: 2005
Posted 03 July 2013 - 02:22 PM
You should not be to sad about the price - in Norway this Focal component set cost about £230....
The rest of the Focal 6,5" component sets range are similary priced here - as they are on amazon.co.uk. So either the Focal PS 165 are a very good buy in the uk or they are very overpriced here in Norway - maybe both? :)
Hope you find a shop with reasonable shipping costs.
#159 Hassen
Hassen
  • 1,097 posts
  • Name: Hassen
Posted 03 July 2013 - 02:38 PM
Thanks Mr_Spock. Even thought Ireland is not too far away from the Uk, the shipping costs have always been high most of the time. I actually picked up my head unit from London as I was on a trip over rather than getting it shipped to Ireland as it would have cost me about £70!
I just wish that funds were available at the moment to get them as I have a bit of free time this weekend and weather permitting, would have liked to spend it installing it in the car. Ah well, will just need to be patient and start saving I guess :)
#160 Mr_Spock
Mr_Spock
  • 83 posts
  • Name: Tom
  • Year: 2005
Posted 03 July 2013 - 02:53 PM
£70 for shipping a Head Unit?? Wow, that is pricy. I bought most of my stereo locally - but the front component speakers came from Kentucky, US - with shipping costing about $70 - and it was a big heavy box.
#161 Hassen
Hassen
  • 1,097 posts
  • Name: Hassen
Posted 03 July 2013 - 08:13 PM
Ah, then it makes sense to charge £25 for shipping the speakers across from the Uk to here even though to Mainland Uk, it's free. Cheapest shipping rate I got so far is £15 to Ireland, which I think is as good as it will get unless I am making a trip across to Uk soon.
Plan then is to save up the next few weeks and then get them at the end of this month maybe. Can't wait to see how they sound in my car!
Still considering getting the whole car sound proofed with Dynamat, which I think will be a major undertaking. I reckon, sound proofing first, then putting in the new speakers for my to do list.
In the meantime, any more suggestions for component speakers in the £100, please share :)
#162 FOCA
FOCA
    Feet on the table
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,867 posts
  • Name: FOCA
  • Ford Model: Mondeo Mk3 Sleeper 194 flb.p.t.
  • Year: Non
Posted 04 July 2013 - 07:10 PM
You could use drive units designed for building hi-fi speakers -  they will probably be cheaper/ better quality than ones for cars, BUT are more likely to be 8 ohms than 4 ohms impedance
If you had a 2-way component system in the front, (with seperate woofer and tweeter) this can be powered from one amp, with a passive crossover,
Or you could have one amp per drive unit (one for the woofer/ one for the tweeter) with an active crossover, this would be realatively expensive, but with the best headroom, sound quality and control (the crossover point can be adjusted better, levels controlled better and the passive crossover(which can introduce distortion) is removed and the amps connected directly to the drive units, even the tweeter)
#163 Hassen
Hassen
  • 1,097 posts
  • Name: Hassen
Posted 04 July 2013 - 11:51 PM
That is something to consider for the future I reckon. The third option sounds like it could get very expensive, very quickly, even though it would sound very good. Think that one will be off the table as I could not justify the cost.
Today, I got some time away from work and family to rewire my car's sound system completely. The first time the car was wired, the amp switch off cable and the rca for the sub woofer were taped together and they were put on the same side as the power cable. When I had wired the front speakers, I had just put the front speaker rca cables alongside the rest. This as a result introduced very annoying hum that got worse while driving. Today, I relocated the front and sub rca wires to the right side of the car while the power cable for the amp is on the left side of the car. It didn't take too long to do and the difference in sound is very distinct! No more hum or buzz from the front speakers and the whole system kicks. I can finally get that thump that I was missing and after a bit of tweaking with the eq and cross over settings, it sounds just the way I like it.
I think for now, the current set up will stay the same for a while until I get bored again. Planning to stick Dynamat and sound proof the car at a later stage. That will be the next project rather than putting in component speakers. But I might change my mind :)
#164 Lenny
    Retired Moderator
  • 10,916 posts
  • Ford Model: Focus ZetecS
Posted 14 July 2013 - 03:22 PM
Sound good on the new system mate,
#165 Hassen
Hassen
  • 1,097 posts
  • Name: Hassen
Posted 14 July 2013 - 09:04 PM
Not really my type of music there Lenny ;)
This is the last song I downloaded to play for my journey to work tomorrow.
Not what you're looking for?
