* * * * * 1 votes
Fiesta Reverse Gear Is Driving Me Nuts
gears
15 replies to this topic
#1 gogopogo
gogopogo
    Newbie
  • Pip
  • 7 posts
  • Ford Model: Fiesta
  • Year: 2009
Posted 03 November 2012 - 11:51 AM
i reckon the fiesta gear box is pants!
i do like ford cars. i've owned a few of them over the years (e.g. escort, mondeo, cougar, focus).
but this is my first fiesta. bought it 3 months ago. reverse gear is driving me nuts. :angry: grinding. crunching. no synchro. wtf? have to wait a few seconds, go via first gear or double clutch it. can't understand why ford hasn't put a good gear box in when everything else about the new mk7 fiesta is great.
has anybody tried swapping the gear box for a good one? is it possible? i guess it's expensive to do but i'm considering whether this is a viable option.
what are you thoughts? ideas?
thanks in advance
#2 alexp999
alexp999
    Serial Poster
  • 454 posts
  • Name: Alex
  • Ford Model: Focus 2.0 TDCi Titanium X
  • Year: 2012
Posted 03 November 2012 - 12:10 PM
I've never been in a car that has a syncro'd reverse gear. Every car I have ever driven if you even remotely still rolling forward when engaging it will crunch.
As for it not going in initially or grinding, I did speak to my local Ford dealer and they said its completely normal for the Fiesta. The tip they gave me was to hold the clutch down for about 3 seconds before engaging reverse
If you feel resistance or it hasn't gone all the way in, it will pop-out or grind when you lift the clutch. If the 3 secs thing doesnt work, then just lift the clutch and pop it back down and it will go straight in.
Like you I used to get so frustrated but having got used to it, I just get in the car and don't think about it now and I haven't had a single issue.
#3 b1g_dav3
b1g_dav3
  • 1,693 posts
  • Name: David
  • Year: 2013
Posted 03 November 2012 - 12:17 PM
Reverse is junk, mine grinds every time I put the car in reverse, great on a hill. Honestly I'm not a big fan of the gear box as a general thing, really needs a 6th gear if honest.
#4 Magenta
Magenta
  • 427 posts
  • Name: Alan
  • Ford Model: Fiesta Mk7 Titanium 1.4 Auto - Marello
  • Year: 2009
Posted 04 November 2012 - 08:52 AM
I had no problem at all with the manual box on my previous Mk 7. including reverse. Ok so I have an auto Mk 7 now but that is not the reason ! I did find the clutch a bit heavy - I assume because it was a diesel. Are diesel clutches heavier than petrol equvalent ?
#5 alexp999
alexp999
    Serial Poster
  • 454 posts
  • Name: Alex
  • Year: 2012
Posted 04 November 2012 - 09:44 AM
Technically the clutch plate and flywheel are heavier on a diesel to handle the torque and smooth out the engine Power but it shouldn't make any difference through the pedal as it's operated by hydraulics.
I think it just depends on how it's been designed, I like quite heavy controls as it gives you more feedback than something over servo'd.
#6 b1g_dav3
b1g_dav3
  • 1,693 posts
  • Name: David
  • Year: 2013
Posted 04 November 2012 - 10:33 AM
With the few 1.4's I've driven I can confirm they're the lightest clutches I've ever found in a car, the diesel is much heavier and in my opinion much nicer to use.
#7 coysht
coysht
  • 405 posts
  • Ford Model: Mk7 Fiesta Zetec S
Posted 04 November 2012 - 12:19 PM
Put it into 5th on your way to reverse and it'll never crunch and will go in 1st time, every time.
Not ideal, but quicker than waiting for everything to stop moving before engaging reverse.
#8 jack_routledge
jack_routledge
    Member
  • PipPip
  • 20 posts
  • Name: Jack
  • Ford Model: Fiesta Zetec S MK7
  • Year: 2009
Posted 04 November 2012 - 01:02 PM
Put it into reverse then take your foot slowly off the clutch with your hand on the gear stick and you'll feel it go in :)
#9 ascowie
ascowie
    Newbie
  • Pip
  • 8 posts
  • Ford Model: Fiesta, Flame
  • Year: 2005
Posted 05 November 2012 - 07:42 AM
I have been having the same problem and its really cheesing me off,
#10 ManxKat
ManxKat
  • 230 posts
  • Name: Kerry
  • Gender: Female
Posted 05 November 2012 - 10:13 AM
Ooh I also have this problem, feel like a typical woman driver when reversing into a space with people watching me because it takes me ages to get it into reverse. Normally I put it into another gear and then and then try again but I will be trying the tips above! Thankies :)
#11 Mordey
Mordey
  • 113 posts
  • Ford Model: 2010 Fiesta zs
Posted 05 November 2012 - 01:41 PM
Works for me every time
#12 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,374 posts
  • Name: Clive
  • Year: 2007
Posted 05 November 2012 - 05:39 PM
Pump the clutch pedal a couple of times, not sure if it mechanically helps but it certainly allows you to time a couple of seconds before engaging reverse.
#13 b1g_dav3
b1g_dav3
  • 1,693 posts
  • Name: David
  • Year: 2013
Posted 05 November 2012 - 07:54 PM
For the new question of gearbox change; Citroen 1.6 diesel box's fit straight in, same engine you see. 6 forward gears, 1 reverse, much better box.
#14 gogopogo
gogopogo
    Newbie
  • Pip
  • 7 posts
  • Year: 2009
Posted 05 November 2012 - 08:31 PM
many thanks for your useful replies and suggestions. :)
i've tried waiting 3-5 seconds before selecting reverse gear - as it says in the owner's manual - but it doesn't always work for me.
i will give all these workarounds a try before deciding on changing the gear box for a better one or changing car for one that's been designed properly (e.g. focus). ;)
#15 zahtar
zahtar
    Member
  • PipPip
  • 18 posts
  • Ford Model: Fiesta Titanium MK7 Frozen White :)
Posted 05 November 2012 - 08:46 PM
I have this reverse gear resistance issue too. If double clutch doesn't work, try this odd thing:
While wheels are totally idle, engage 4th gear and then reverse. It always works for me, not grinding etc. My brother (MK6 facelift owner) told me this trick.
Try never to force any gear in. I did it to my mom's peugeot 205 many years ago and the stick broke from its base...
