1.4 Diesel Ford Fiesta Titanium (2009) Beeps When Ignition Is Switched On. Help?
Started by Neo222, Nov 06 2012 07:23 PM
troubleshooting error warning beeping startup help
11 replies to this topic
#1
Posted 06 November 2012 - 07:23 PM
Hi guys, this is my first time posting so I hope I'm posting this in the correct place.
I have recently bought myself a 2009 1.4 Diesel Ford Fiesta Titanium. Ever since I bought it, it always beeps about ten times (as you can hear in the video, link below) when the ignition is switched on, but doesn't do this at any other time during a journey. It is only after speaking to one of my friends who has a fiesta that I found out that this isn't normal. No warning lights show and everything feels like it is working fine, there is nothing in the manual/handbook about any beeps or what they mean. I'm just a bit concerned that it could be something serious. Does anybody know what this means, or what is causing it?
Here is a link to a video of my car showing the problem:
Thanks in advance,
Sam
Thanks in advance,
Sam
#2
Posted 08 November 2012 - 08:37 AM
Does the car have a tracking device installed? Some tracking devices require tags, and the tag reader can beep when it searches for tags.
I have a 1.25 zetec , sister in law has a 1.6 TDCI titanium and never heard this before.
#3
Posted 08 November 2012 - 11:53 AM
It really does sound as the car thinks its been nicked and then changes its mind.
Do you have 2 sets of keys. If so does it do the same with both sets
#4
Posted 08 November 2012 - 01:52 PM
Thanks for your replies. I was only given one key when I bought the car, and I wasn't told anything about it having a tracking device installed. If it did would there be a way of checking apart from the beeping?
Is this problem likely to be show up when a diagnostic tool is used to check for errors?
Thanks again
Thanks again
#5
Posted 08 November 2012 - 05:49 PM
ID give it a try if you have accesss to one
#6
Posted 08 November 2012 - 08:17 PM
Ran a diagnostics/fault check with a ProScan V580 and it showed up with no errors
. Any ideas what I should do now or what else I could check. Also on an extra note if I turn off of warning chimes it doesn't beep when the ignition is on but instead beeps when I turn the engine on.
#7
Posted 08 November 2012 - 08:43 PM
This may seem odd but it doens't sound like a Ford beep.
All my beeps are doorbell or siren in style (ie low fuel, lights on, door open/ no seatbelt) and the display shows the error, that one sounds too "simple"
If you go into the menu and information messages does that say anything? Probably won;t but worth looking.
#8
Posted 08 November 2012 - 09:15 PM
Yeah it doesn't really sound like any of the others, just popped out and had a look and there are not messages either.
#9
Posted 08 November 2012 - 11:14 PM
This may sound odd but I notice from the video that you have some lights selected(not sure which what they are mine doesn't have it) on the dial next to the steering wheel does it still do the beeping when they are turned completely off ie on the 0 sign
#10
Posted 08 November 2012 - 11:54 PM
Automatic lights that selection on the dial is. That shouldnt cause a beep. Lights only cause a beeping if u leave ur dipped beam on when about to turn the engine off.
#11
Posted 09 November 2012 - 12:09 AM
Ah ok must be a titanium feature and I know it should only beep when you leave your lights on and open a door. Wondered whether it was a beep to say the lights had come on or auto was selected
#12
Posted 09 November 2012 - 06:02 AM
I can tell you exactly what that is, i'll lay bets that your car had a Parrot Bluetooth system fitted at some time and they've removed the controller and microphone but left the main unit fitted.
It's the main unit beeping to tell you that the parrot has a missing component or a disconnected cable.
When i got my car a Parrot was already fitted and the control unit had a loose connection and kept making that noise when knocked.
If you look behind your radio or behind the glove box you'll likely find a blue box like one of these-
If it isn't that i'll eat my Public Order Helmet.
Also tagged with one or more of these keywords: troubleshooting, error, warning, beeping, startup, help
Welcome to Ford Owners Club →
New Member Introductions →
New Memeber - New ProblemStarted by danskihill, 16 Jun 2013 |
United Kingdom - General Ford Discussions by Model →
Ford Fiesta Club →
Remove / Replace Wing Mirror CoverStarted by PaulHigson, 12 Jun 2013 |
Ford Fiesta Club →
Mk4 Fiesta Zetec S Clutch Change. Quick Reply Please!Started by JacobOsborne, 10 Jun 2013 |
Ford Fiesta Club →
Fiesta Zetec S 11 Plate Help!Started by BennieFaeDenny, 07 Jun 2013 |
General Ford Discussions →
Escort VanStarted by t9swc, 05 Jun 2013 |
