Help required...
Car details: Fiesta MK5 (2001) Endura-E 1.3 engine.
Steam started coming up from under the bonnet yesterday and we discovered a small jet of coolant spraying from inside the engine. At first we thought it was the pipe heading in to the oil filler cap, but on further inspection there is a hole in the engine block which is spraying out water when the engine is hot.
I've attached a photo of the offending hole. I'm sorry that there isn't much context to it as it's a bit of a close up. If you can't tell where it is I can try to describe it... As you look into the engine bay from the front of the car, it is on the right-hand side, vertical part of the engine block.
What I ask is, how easily can this be repaired? Anybody with any experience of this?
Cheers,
Liam
Hole In Engine Block Spraying Coolant On Mk5
Started by lpgaff, Nov 07 2012 12:10 AM
coolant engine leak help mk5 fiesta endura 1.3
7 replies to this topic
#1
Posted 07 November 2012 - 12:10 AM
#2
Posted 07 November 2012 - 09:03 AM
Looks like a leaking core plug to me. After the engine block is cast certain holes need plugging so as to allow the waterways to be sealed. One of your plugs is leaking.
Not sure how easy it is to replace on your particular engine - some of the more experienced mechanics should be able to further advise.
#3
Posted 07 November 2012 - 06:24 PM
Should be an easy fix.
Get some new core plugs ordered and "plug that hole"
#4
Posted 07 November 2012 - 08:10 PM
They say its easy. The problem is likely to be getting the old one out. I would let someone else do it as the only time I have done one was at the side of the road in a Ford Corsair back at the end of the 70's. The plug popped out and fortunately landed on the pipes and stayed there. I pushed it back in with some ring spanners and never had a problem with it after that. It didnt even leak.
#5
Posted 07 November 2012 - 11:38 PM
My son had two leaky core plugs replaced in his Mk6 1.25 cylinder head recently and the cost was about £30 including VAT and antifreeze so it cannot be too difficult. The core plugs themselves cost pence. There are YouTube videos showing how they are replaced if you do a search for "Core plug replacement".
#6
Posted 08 November 2012 - 11:36 AM
The core plugs in the later engines are in the top of the head and screw in. Unfortunately these older core plug types dont.
#7
Posted 08 November 2012 - 08:21 PM
Thanks everybody. Took it along with the knowledge that it was the core plug. I was charged £40 to replace it, refill with anti-freeze and get rid of the airlocks. The last but took a while but it wasn't as disastrous as I first thought when I saw steam pouring up through the bonnet!
Thanks again for all your suggestions. Super!
#8
Posted 08 November 2012 - 08:25 PM
Also, he said we were lucky because it's one of 6 (IIRC), and the easiest one to get to. The others require much more dismantling and a few more man hours.
Got the old core plug out too, amazing how much it had corroded on one side. Make sure you refresh your antifreeze/coolant regularly!!
Also tagged with one or more of these keywords: coolant, engine, leak, help, mk5, fiesta, endura, 1.3
Ford Modifications and Projects →
Ford Projects and Builds →
Scarlett - My Fiesta Mk3Started by Mrmark941, Yesterday, 09:07 PM |
Ford Modification Discussions →
Fiesta St InteriorStarted by Maniac Mart, Yesterday, 06:14 PM |
United Kingdom - General Ford Discussions by Model →
Ford Fiesta Club →
Issues Timing My EngineStarted by RDelaCourt, Yesterday, 11:17 AM |
Ford Fiesta Club →
Fiesta Metal Headlights ProblemStarted by Rokket, 14 May 2013 |
Ford Fiesta Club →
!!!!!!! Help!!!!!! With Interior Door PanelStarted by D13 HPD 95, 13 May 2013 |
Latest Comments
More
