Problems With Fiesta
Fiesta Climate control Blowers Windows steaming up
5 replies to this topic
#1 Ellie12
Ellie12
    Newbie
  • Pip
  • 1 posts
  • Ford Model: Fiesta titanium 2012
Posted 09 November 2012 - 07:36 AM
I've had my fiesta titanium 12 plate for a couple of months now, I'm constantly having problems with the windows steaming up, it doesn't matter what the weather is like, it always steams up, is there anything I can do about it?
Also, to clear it, I put my blowers on, but as my model has climate control, does this consume fuel? I never use the auto or a/c button but just the left hand dial which comes on and says blowers, on the screen but when I turn it off, it says climate control off. Would this still use my fuel up? If so, there shouldn't there be a way to use the blowers without that happening as I would rather not have climate control then.
I would really appreciate any advice, thanks!
#2 Mariner
Mariner
  • 40 posts
  • Ford Model: Mk 7 Fiesta Titanium 1.4
  • Year: 2009
Posted 09 November 2012 - 08:49 AM
It will only use more fuel with the AC on.
Set the temp to desired level (try around 22 to start with) and leave the fan on Auto all the time. Should solve the problem.
If the car is really steamed up inside then switch AC on for a while - will clear it in no time.
#3 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,238 posts
  • Name: Daniel
  • Ford Model: Fiesta Mk6 1.3 Petrol
  • Year: 2003
Posted 09 November 2012 - 06:07 PM
You can also get antifog glass cleaner and if you clean the inside windows with it every 3-4 weeks it also stop the problem :)
#4 lyonsb123
lyonsb123
  • 42 posts
  • Name: Bradley
  • Ford Model: Fiesta Metal
  • Year: 2012
Posted 11 November 2012 - 02:35 PM
Make sure the side air vents (the ones that spin 360 degrees and close flat) are pointed towards the side-windows as well. Then leave the blower on the front-facing setting, and the windscreen setting. This should stop both the front and side-windows steaming up (does for me, anyway)
#5 colin79666
colin79666
  • 121 posts
  • Name: Colin
  • Ford Model: Fiesta Titanium 1.4
  • Year: 2012
Posted 11 November 2012 - 04:31 PM
Best to use the AC/Climate Control (at least some of the time). If you never use it then the system will dry up and the pipes will split. Also using it helps to dry the incoming air and defog the windows much quicker.
#6 Marcr1
Marcr1
  • 801 posts
  • Name: Marc
  • Ford Model: Fiesta S1600
  • Year: 2012
Posted 11 November 2012 - 04:50 PM
Make sure you don't have any drinks bottles laying around or anything as these can cause the windows to mist up.
I find the leather seats cause my windows to steam up a bit quicker than previous cars I've had, probably due to the cotton absorbing the moisture better.
The AC uses cleaner air if you like so helps to de-mist the windows much faster
