Ford Focus Mk2 Courtesy Light, Boot Light And Glove Box Light Upgrade
#16
Posted 12 November 2012 - 10:31 PM
Went to investigate and it was a nice little surprise. Just shows though as the driver, when do you ever really sit in the back of your car to notice? Been turned off the whole time so I'd never have known.
I text the Missus to tell her n next thing she put her coat n shoes on n come outside in the cold for a mooh cause she didnt know how she'd never seen it either.
#17
Posted 12 November 2012 - 10:38 PM
Any excuse eh?
#18
Posted 13 November 2012 - 02:28 PM
http://www.ebay.co.u...=item20c5e32d73
Also thanks for the heads up on them often having a flakey connection, sure I've got something to sort that out.
So I checked for the footwell light and the plastic moulding is there but no socket or wiring
Also think I'll go for this one with the sunglasses, any ideas what that little black plastic bit with the ball on the end is (top left of the pic)?
#19
Posted 13 November 2012 - 03:18 PM
#20
Posted 13 November 2012 - 03:24 PM
Thanks for all the advice/pics Charlie, appreciate it. Those panels really light the whole boot up! These would be the white equivalent? Real cheap from hong kong but might see if I can find a UK seller if it isn't much more (easier to return if they don't work/stop working after a while).
So I checked for the footwell light and the plastic moulding is there but no socket or wiringis that going to be much of a pain to install?
Yes those are what you want in white. You won't be disappointed. Yes theres UK sellers, think they'll be about 3quid each though so like twice the price, still cheap though. Like I said with the flakey connection, just a blob of sealant or glue in the wedge adapter and your sorted.
#21
Posted 13 November 2012 - 03:43 PM
#22
Posted 13 November 2012 - 03:55 PM
Steven, I'm not sure about the wiring looms on the facelifts, but retro-fitting interior lights is dead easy as it's just a matter of tapping into the existing loom if need be. The bravery part is required for the roof lining cutting, but even this is straightforward if you take a lot of care. Keep in mind, it's easy to take an extra little bit off if your initial cut is too small - not so easy to put it back on if you cut it too big!
#23
Posted 13 November 2012 - 04:19 PM
If stuck on at all...mine is a little clip fitting which I have at the top of my driver side A-pillar.
cheers mate, i always knew that it if need be I could splice into the courtesy light loom, but my knowledge of electronics and splicing/crimping/soldering skills are non-existent! if it was a plug and play job i'd definitely give it a go though! I keep meaning to remove the light and have a peek at the wiring but keep forgetting to. My girlfriend is off for a long weekend though this weekend and I plan on giving the car a day long clean and prep for winter (including an attempt at a few stone chip repairs
#24
Posted 13 November 2012 - 05:18 PM
Saw the posts about the rear courtesy light so I had to go and check, didn't I
Sure enough I have it and it was working. I had a spare blue LED festoon from when I did the front, so, out with the old bulb - can't find that any more so will have to wait for daylight - fiddled around offering up the LED, dropped a couple of times and then bingo, it disappeared through that gaping hole into the headlining. Gone for ever so I hope it doesn't rattle.
Trouble was that that was 38mm and the holder needs 42mm.
42mm blue ordered but I will bung up that hole before I try to fit.
Fiddly job, can't hold bulb properly to offer it up, and I don't have fat fingers
#25
Posted 13 November 2012 - 06:16 PM
Anything to give you guys a laugh.
You mean you had a rear courtesy light and never noticed either mate?
#26
Posted 13 November 2012 - 07:28 PM
#27
Posted 13 November 2012 - 08:19 PM
#28
Posted 13 November 2012 - 08:49 PM
#29
Posted 13 November 2012 - 10:25 PM
http://www.ebay.co.u...984.m1497.l2649
Hope this helps.
#30
Posted 13 November 2012 - 10:34 PM
Also tagged with one or more of these keywords: courtesy light, boot light, glove box light, LED, ford focus mk2
United Kingdom - General Ford Discussions by Model →
Ford Focus Club →
Focus Zetec S 1.6 Mk 2.5 Can-BusStarted by atherm3, 15 Mar 2013 |
Ford Fiesta Club →
Mk7 Fiesta Titanium Footwell LightsStarted by Shannon Sloan, 06 Dec 2012 |
Ford Focus Club →
Light RecommendationsStarted by k13r4n, 16 Nov 2012 |
Ford Focus Club →
Ford Focus Mk2 Day Time Running LightsStarted by PaulE, 09 Nov 2012 |
General Forums →
Audio & Electronics →
Change Boot Light For Led StripsStarted by Mrmark941, 15 Sep 2012 |
Latest Comments
More
