thomash
Door Sensor For Dash Lights Etc...
5 posts in this topic
I've had a problem with my driver side door for a while and now it's coming to winter I don't want to forget that my lights are on all the time, i'd like to hear the 'ding' noise etc..
Does anyone know if there are fuses for each door sensor? All the other doors work (information on dash shows).
Is there a fuse for all - if so then there is obviously something wrong with the door catch...
Would anybody be able to point me in the right direction of what to be looking for, or if anyone has had the same issue and resolved it?...
Or does anyone actually know what this part is called, as door sensor doesn't bring up anything in searches for parts.
I have a FORD FOCUS 2007 Sport.
Many Thanks for any feedback.
AFAIK, the fuses that operate that switch are the same as the door lock mechanisms so pulling the fuses will result in the locks not working
The switch is integral to the lock unit, try blasting some WD40 in to loosen any stuck springs etc..
Search for courtesy light switch
Me too! Small world ;)
Many Thanks for your help Clive,
I never received an email when you replied so sorry for the delay, i'll try the wd-40 and the new search term "Courtesy Light"
I'll let you know how I get on...
Hi (thomash).
Did you solve your courtesy light problem? My Focus 1.6TDCI has got the same problem.
Thanks.
