Mk Mondeo Tdci 54 Plate
11 replies to this topic
#1 Maddogpro
Maddogpro
  • New Member
  • 107 posts
  • Ford Model: Mk3 Mondeo tdci autoest
  • Year: 2004
Posted 17 November 2012 - 08:59 AM
Footwell behind driver is damp is this the rear washer hose ? Does anyone know or have a definate route for the hose i.e from the nozzle too the washer bottle or which bits of trim too remove too find the pesky thing or am i barking up the wrong tree with this
Cheers the Dawg
Have something to contribute?
#2 ppeter7
ppeter7
  • Budding Enthusiast
  • 328 posts
  • Name: peter
  • Ford Model: mondeo 1.8/ mondeo 2.0 zetec
  • Year: 2001
Posted 17 November 2012 - 10:50 AM
hi if you lift tail gate and take off the top trim by brake light the pipe gose off to the left through the small grommet into roof area.but you would notice a drop in winscreen fluid to. i would check rubber seals around doors and windows and in floor to hope this is some sort of direction for starters
#3 Maddogpro
Maddogpro
  • New Member
  • 107 posts
  • Year: 2004
Posted 17 November 2012 - 11:34 AM
Thanks ive checked the doors and window by running the garden hose around them all seems good thats what leads me too think somewhere is a joint in the rear washer hose as in a joint come adrift somewhere but the side panels have airbags and i dont know if would be ok too pull/unscrew them
#4 ppeter7
ppeter7
  • 328 posts
  • Name: peter
  • Year: 2001
Posted 17 November 2012 - 01:25 PM
could also check by putting forward the rear seat and take trip apart and lower kick trim cause it routes down that way if memory correct
#5 Maddogpro
Maddogpro
  • New Member
  • 107 posts
  • Year: 2004
Posted 17 November 2012 - 01:55 PM
Thank peter iwill have a nosey if i get chance this afternoon if not tomorrow i will take the camera with me
#6 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,551 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 17 November 2012 - 05:00 PM
there is a joint that splits but this is usually located behind the near side rear passenger seat behind the small side panel near the seat headrest.
#7 Maddogpro
Maddogpro
  • New Member
  • 107 posts
  • Year: 2004
Posted 17 November 2012 - 06:34 PM
Now that,s thrown a spanner in the works cos its def drivers side footwell in the rear maybe mine is an oddity are there any grommets under neath that side ? in the floor pan or maybe the dooor is filling via the glass and holding water which in turn comes in that way looks like a busy day tomorrow
#8 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,551 posts
  • Name: mintalkin
  • Year: 2006
Posted 17 November 2012 - 08:26 PM
i would remove the doorcard and check the plastic membrain on the door also check that the drainholes in the door are not blocked.
#9 Maddogpro
Maddogpro
  • New Member
  • 107 posts
  • Year: 2004
Posted 18 November 2012 - 04:24 PM
The moral of my story is if your nipples blocked your bottoms gonna get wet !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
After all that pishing about door cards off oh and ford you think your cute hiding a fixing under a cover in the door handle but the dawg outsmarted ya on that one . :ph34r: .....The door was clean and dry took the rear seats out carpet up no obvious entry point apart from two grommets pone either side but not them either ......decided too start at the top sat in rear and pondered were does that hose run so that was it trim out off offside left rear nope not there then onto headlining and its taped too the !Removed! headlining about 8" in form the side no leak there by this time and 10 cigs later :wacko: i thought [genius see if the rear washer actuall does anything gets keys ign on pulled lever noise yes water no] so the two phillips screws in the rear high level brake light and hey presto the the hose wasn,t even connected i can only assume the nipple was blocked and the pressure had forced the hose off so pliers out nipple off a good blow with a can of comp air put back in hose firm cable tied insitu and bobs your uncle job done..... :D :D :D :D So ford its dawg 1 you nil ....Who says a scooby boy cant fettle a ford :ph34r:
#10 garbage456
garbage456
  • New Member
  • 45 posts
  • Ford Model: fusion 2003 and mondeo 2001
  • Year: 2001
Posted 20 November 2012 - 02:55 PM
+1 like
#11 ppeter7
ppeter7
  • 328 posts
  • Name: peter
  • Year: 2001
Posted 20 November 2012 - 05:58 PM
lol i did say check lol
#12 Maddogpro
Maddogpro
  • New Member
  • 107 posts
  • Year: 2004
Posted 20 November 2012 - 05:59 PM
Ok ok oh wise one :P
Not what you're looking for?
