New Alloys
18 replies to this topic
#1 PjFocus
PjFocus
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Ford Model: Focus
Posted 21 November 2012 - 06:23 PM
New wheels catching on arches, alloys, 225x45 r17.
Hi guys and girls. Just upgraded my wheels from the standard 205 55 r16 steel rims that came on my focus mk3 (2005- ) to a set of alloys of a jag that are 225 45 r17. They went on a dream and look amazing but took them out for a test drive and my fears were realised. As I corner it seems the wheels are catching inside the arches. The tyres are in good shape so don't want to change to lower profiles just yet and was hoping someone might have info about spacers (thickness / practicality etc) in any case I'm going to get under it to find out exactly where the contact is being made but any further info would be great.
Have something to contribute?
#2 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,547 posts
  • Name: Clive
  • Year: 2015
Posted 21 November 2012 - 08:29 PM
Are they catching the rim of the wheel arch or up under the arch liner?
If it's the rim then I'd say the offset is wrong.
#3 salsheikh
salsheikh
    Sal_Sheikh
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,063 posts
  • Name: Sal
Posted 21 November 2012 - 09:35 PM
i think he means the arch liners Stoney as it happens when he corners. surprised by this as i have 19's and they dont catch (235/35/19 tyres) against 225/45/17 for the OP.
#4 PjFocus
PjFocus
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Ford Model: Focus
Posted 21 November 2012 - 10:26 PM
Could it be that I also have coil-over suspension fitted? There's still clearence at the top and front to back but at I turn there's just a hint of knocking and it feels as if its rubbing.
#5 Stoney871
Stoney871
  • Super Mod
  • 18,547 posts
  • Name: Clive
  • Year: 2015
Posted 21 November 2012 - 10:29 PM
Ah yes!
That would do it.
#6 PjFocus
PjFocus
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Ford Model: Focus
Posted 21 November 2012 - 10:30 PM
And yeah, inside the arch against the liner, not the outer lip.
#7 PjFocus
PjFocus
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Ford Model: Focus
Posted 21 November 2012 - 10:34 PM
okay, that being said then, apart from winding the suspension back up, what's my best bet for resolving it? I was considering spacers to try and push the wheels out just enough so they don't catch.
#8 Mike77
Mike77
  • 959 posts
  • Name: Mike
  • Ford Model: Fiesta 1.6 TDCI Titanium
Lol, I was scratching my head at the first post, working out tyre sizes in my head and thinking 'that should be fine'. Glad to see you missed one tiny bit of info about the coilovers haha. Everything makes sense now.
#9 salsheikh
salsheikh
    Sal_Sheikh
  • PipPipPipPipPip
  • 2,063 posts
  • Name: Sal
Posted 22 November 2012 - 12:58 PM
so what is required to solve this problem then?
i was thinking of eibachs or collies so some info would be great!
#10 Mike77
Mike77
  • 959 posts
  • Name: Mike
Posted 22 November 2012 - 02:15 PM
Only 2 options really, either wind back the coil overs so the ride height is slightly higher, or try some spacers, careful with the spacers though, make sure the tyre does not protrude from the wheel arch as that will attract attention from the boys in blue. Also you will require longer wheel bolts.
#11 PjFocus
PjFocus
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Ford Model: Focus
Posted 22 November 2012 - 06:38 PM
Spacers was my initial line of thought, iv been told i can get away with spacers upto 10mm without having to change the bolts. Longer wheel bolts will mean taking apart the wheels assembly won't it (wheel off, disc off and take out the bolts)
#12 Mike77
Mike77
  • 959 posts
  • Name: Mike
Posted 22 November 2012 - 06:58 PM
Your thinking of studs, not bolts. I'm sure mine are bolts, which would just be a simple case of getting longer ones. But if it is studs, then yes, its gonna be a bit fiddly. 10mm might not sound like much, but that's quite a few turns of the wheel nuts your gonna be losing, and I'd be concerned as to weather you'll be able to get the wheels on correctly and more importantly SAFELY.
#13 Stoney871
Stoney871
  • Super Mod
  • 18,547 posts
  • Name: Clive
  • Year: 2015
Posted 22 November 2012 - 07:54 PM
Correct, the tyre tread must be level with or inside the outer lip of the wheel arch to be legal and safe.
The side wall or rim can protrude but not the tread.
#14 artscot79
artscot79
  • PipPipPipPipPip
  • 7,995 posts
  • Name: arthur
  • Year: 2006
Posted 22 November 2012 - 09:39 PM
beware of advice like the original bolts will be fine a reputable tuning company done my sisters pug 306 and said the same thing with 10mm spacers till 2 bolts on the passenger side sheared whilst driving at 50mph the wheel then ended up going up into the arch and ripping the wing off a decent tuner told her with the coilover suspension the stress was too much and that the bolts would have worked on a standard suspension only and that they dont recommend any spacers when using coilovers
#15 PjFocus
PjFocus
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Ford Model: Focus
Posted 23 November 2012 - 01:06 AM
I'm not sure I understand why the suspension affects using spacers and longer studs? Surely the two have no baring on each other...
Not what you're looking for?
