Changing Heater Control Valve
ford fiesta heater
1 reply to this topic
#1 Meeee
Meeee
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: Fiesta 2001 freestyle
Posted 23 November 2012 - 03:13 PM
Hi
I have just purchased a Ford fiiesta 2001 freestyle for my Daughter, however I did notice the heater did not work (Always blows cold air) So I am presuming it is probably the heater control valve.
I am guessing I will need to drain the coolant from the system before replacing it? If so is there any particular coolant I should fill the system back up with or can I just use the normal stuff from Halfords.
Also I am guessing there will be a drain pug to drain the system under the radiator?
Any advice would be appricated
Meeee
Have something to contribute?
#2 btmaldon
btmaldon
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 2,587 posts
  • Name: Bruce
  • Ford Model: KA Edge, BMW 320i Coupe M Sport
  • Year: 2015
Posted 23 November 2012 - 04:52 PM
I would pull the hoses off and let it drain whatever is in those pipes. You will only need a litre of antifreeze if that and top up with water.
It should have the pink stuff in the coolant but if it has had the blue stuff I would get that as you dont want to mix it. Just check it meets Fords requirements.
Not what you're looking for?
