Aircon Focus C-Max
2 replies to this topic
#1 Mabbs
Mabbs
    Newbie
  • Pip
  • 1 posts
  • Ford Model: Focus C-Max 1.6 TDCI
Posted 23 November 2012 - 06:24 PM
Hi
Own a 2004 (54) C-max and Aircon is not blowing cold air. It is newly re-gassed.
I was looking at the fuse diagram and see that 'Aircon Clutch Solenoid fuse' is missing from slot 15 of the under bonnet fuse box (F1510a).
Since I have never been in the fuse box and not sure anyone would actually need to can anyone tell me if the fuse is really needed?
Mabbs
#2 Stoney871
Stoney871
    Resident Lawman
  • Super Mod
  • 8,399 posts
  • Name: Clive
  • Year: 2007
Posted 24 November 2012 - 01:40 PM
If the system has been recently worked on and is not working then how did they check the system?
Part of the process would be to run the A/C and check temperatures at the vents.
Without the clutch solenoid fuse in place the pump would not engage therefore no compression of gas and no coolant will cycle.
I would suggest you return to the person who did your A/C and make enquiries.
#3 NorthSussex
NorthSussex
  • 972 posts
  • Name: Stormin
  • Year: 2009
Posted 24 November 2012 - 03:49 PM
You could have a leaking aircon condenser or compressor resulting in a loss of gas. It needs a dye put through the system to check for leaks, this should have been done on the re-gas.
