Rattling/squeaking In The Rear Of The Car
6 replies to this topic
#1 King coz
King coz
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Ford Model: Fiesta zetec s
Posted 28 November 2012 - 05:29 PM
Hi everybody,
I purchased a ford fiesta zetec s 59 plate in July
I have been over the moon with it until recently when I have discovered a squeaking noise coming from the boot area / rear window.
It is driving me crazy, I have even put people in the boot to try and identify what it is but they can't point a finger on it
I took the spare wheel out and the jacks as I thought it could have been that, even took the parcel shelf out but it still continues to annoy the hell out of me!
Not sure if this Is a common fault or not
I would really appreciate it if somebody could help me out
Thanks in advance
Have something to contribute?
#2 DanGersFord
DanGersFord
    Dan The Gas Man
  • New Member
  • PipPipPipPipPip
  • 3,498 posts
  • Name: Daniel
  • Ford Model: Fiesta ST3
  • Year: 2014
Posted 28 November 2012 - 11:46 PM
Hi, I had a squeeking noise from the back of the car aswell not too long ago and I took it into my local ford garage who said its quite a common problem. If you look under the car just above the exhaust theres a kind of metal foil heat sheild and it will have come loose. You can either replace it or just remove it all together. The ford garage said its not important and its fine to just get rid of it altogether. Hope this helps
#3 sambooka
sambooka
    Sam Oglesby
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 1,034 posts
  • Name: sam
  • Ford Model: mk7 fiesta zetec s
  • Year: 2009
Posted 29 November 2012 - 02:35 AM
If your handbrake pulls up high then the squeaking could be coming from your rear brakes had it on mine just adjusted them and cleaned the drum out as there was a few bits of brake shoe rattling around
#4 jimrex
jimrex
  • Budding Enthusiast
  • 580 posts
  • Name: James
  • Ford Model: 2011 Mk3 Focus, 2009 Mk7 Fiesta
  • Year: 2011
Posted 29 November 2012 - 09:23 AM
Our Fiesta used to rattle from the boot area and it turned out to be the boot latch - it's quite a common problem and has been covered on here in the past I think.
As a quick fix, I wrapped the latch in a thick layer of electrician's tape and it's never done it since. Give that a go!
#5 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,087 posts
  • Name: Clive
  • Year: 2015
Posted 29 November 2012 - 05:19 PM
Check that the rubber boot stops are making contact with the hatch, if not then sometimes the hatch will bounce a bit.
#6 jimrex
jimrex
  • 580 posts
  • Name: James
  • Year: 2011
Posted 30 November 2012 - 09:31 AM
True... our Fiesta also had longer rubber stops fitted by the dealer :)
#7 King coz
King coz
    Newbie
  • New Member
  • Pip
  • 3 posts
Posted 30 November 2012 - 09:46 PM
Thanks for all your replies. I'll have a play around tomorrow and see what I can do
Fingers crossed i'll get it sorted!
Not what you're looking for?
