AdBlock Warning
rexleroy
Tyre Pressures
12 posts in this topic
Hi can someone help me.I have a fiesta titanium 1.6 petrol with bridgestone low profile tyres size 205/40/R17.What is the correct tyre pressure yours george.
It should say on the inside of the passenger side door. I have the 17"s aswell, I think its 28 PSI, but don't quote me on that.
This should be stuck to the passenger door pillar.
post-35558-0-97500200-1354193860_thumb.j
I best put some air in mine have always but 28ish in as when I put more in ford said they were overinflated when it was serviced shows how much they know
That should be there, but 3 door if you have 3 door model. Less weight, less PSI needed. 28 should do, also depends on how much weight there is in your car (inc the engine) - 1.6 should be 30PSI 1.4/1.25 28/29 ish.
31 on front & 26 on rear, that's probably why you were told they're overinflated Sam (rear at least anyway)
Probably yes as I always do them all the same (28psi)
I've always done 30-32psi on the 195/45 16's. I believe they changed the psi on the newer models. I've taken it to rapid fit ford a few times and they've never said anything.
@Dieselpig that must be the newer sticker as the 195/45/16's for the front where 26psi.
Don't know any different my 3 door was made in June 2011.
What are the side effects of over inflated tyres? If anyone knows
I actually just did a google and found out :P
This picture makes an interesting point:
