Summer To Winter Tyres
#1
Posted 29 November 2012 - 06:16 PM
I currently have the new shape focus on an '11' plate... Its the titanium x model that comes with the 18" alloys with Michellin Pilot Sport 3's 235/40 ZR18 as standard... I already owned a set of winter tyres which I used to put on my old car but this car had the 16" alloys on. So I have purchased 16" steel wheels and had the Michellin Alpin A4's 205/55 R16 fitted to them.
I've now swapped my wheels over and thought all was good until I called into my local ford dealer today when he told me I may well of now invalidated parts of my warranty by swapping to smaller wheels but also that i've possibly caused lots of problems now and that i should have the car reprogrammed with the wheels set at this new diameter and at a cost of around £50 !!!!!! As the speedo, abs, trac control etc all work off the wheel size....
Is this correct or am I been fed a bit of nonsense???
Cheers
Paul...
#2
Posted 29 November 2012 - 06:52 PM
#3
Posted 29 November 2012 - 07:04 PM
#4
Posted 29 November 2012 - 07:17 PM
#5
Posted 29 November 2012 - 08:53 PM
Yes your winter tyres are on a smaller wheel, but the important fact is that the sidewall profile is larger to compensate for this.
The actual rolling radius of the tyre is only 2% different, which is absolutely fine and well within normal limits.
I checked on a tyre comparison website:
http://www.etyres.co...-calculator.htm
Your standard wheel/tyre has a total diameter of 645mm
Your winter wheel/tyre has a total diameter of 632mm
The difference in total diameter is 13mm
That's the difference between a new tyre and a worn-out tyre
(New tyre has 8mm tread, legal limit is 1.6mm, so you lose 6.4mm per side. Total loss of diameter is 6.4 x 2 = 12.8mm)
It's just maths.
Is the dealer suggesting that you have your speedo calibrated as your tyres wear out? And then again as you buy a new set?
And what warranty parts could possibly be invalidated? If anything, your winter tyres will have better ride comfort because of the deeper sidewalls, and that will mean less shocks through the suspension etc.
Try going over a pothole on each set of tyres...
He's yanking your chain.
#6
Posted 29 November 2012 - 09:24 PM
but driving the car tonight i had my tomtom on and on cruise control the speed on the satnav was within 3 or 4 mph of what the speedo was reading...
#7
Posted 29 November 2012 - 09:45 PM
They'd likely put the car in the bay for two hours while they go for a !Removed! break and an extended lunch, return it to you and charge you for the honour.
Was he wearing a striped jumper and a black mask?
#8
Posted 29 November 2012 - 10:14 PM
#9
Posted 30 November 2012 - 01:33 AM
#10
Posted 30 November 2012 - 11:15 AM
He was angling for work.
Or was he riding around on a horse
#11
Posted 30 November 2012 - 05:06 PM
A !Removed! Turpin without the Turpin.
