Support the club!
Front Discs And Pads
7 replies to this topic
#1 ippy
ippy
  • 66 posts
  • Name: ian
  • Ford Model: mondeo 2.0 tdci ghia x auto
  • Year: 2004
Posted 02 December 2012 - 07:41 PM
how east it to change front discs and pads on the front? any special tools req? or is it a garage jobby? :unsure:
#2 ppeter7
ppeter7
  • 216 posts
  • Name: peter
  • Ford Model: mondeo 1.8
  • Year: 2001
Posted 02 December 2012 - 07:52 PM
very easy just need 13 and 12 mill spanner for calliper guide bolts copper ease grease.17 mill socket for calliper to knuckle bolts flat blade screw driver to push back the pads into caliper and about 45mins to do the front both sides no need to undo any brake pipes regards pete
#3 btmaldon
btmaldon
  • PipPipPipPipPip
  • 1,589 posts
  • Name: Bruce
  • Ford Model: Focus Sport
  • Year: 2011
Posted 02 December 2012 - 08:01 PM
I would use some threadlock on the carrier bolts. You don't want those coming undone.
#4 PeanuckleJive
PeanuckleJive
  • 56 posts
  • Ford Model: Mondeo Estate 2.0 TDCi Zetec
Posted 02 December 2012 - 10:31 PM
Yup, very easy to do indeed!
Careful not to twist your brake line by accidentally spinning the caliper round while working, MOT failure if spotted!
#5 BigD
BigD
  • 122 posts
  • Ford Model: Mondeo 2.0 TDCI Mk3.5
  • Year: 2005
Posted 06 December 2012 - 10:20 PM
Ideally you'll want a torque wrench to torque the slider bolts up correctly to 30Nm. They are very useful things to have lying around the garage. I have 3!
Also, I've just done the rears on mine and don't know about the fronts, but the rear calipers need to be wound back in, not the push-in type. The n/s wind in clockwise, and the o/s wind in anti-clockwise. If there are two notches in the caliper face, then its a wind-in type. You can buy special tools but beware as some only wind in a clockwise direction. I used an angle grinder spanner (for changing grinder discs) with no more than thumb pressure and didn't have any problems (other than winding it the wrong way at first!).
#6 ippy
ippy
  • 66 posts
  • Name: ian
  • Year: 2004
Posted 07 December 2012 - 02:11 PM
:) thank you every1, looks like im gonna get cold out there doing it at the w/end just got to get the discs and pads and we're off,
cheers guys
ippy
#7 kmukz83
kmukz83
    Newbie
  • Pip
  • 4 posts
  • Ford Model: Mondeo Mk3
Posted 14 January 2013 - 09:10 PM
A G-Clamp and the old pad to push back the piston
#8 BigD
BigD
  • 122 posts
  • Year: 2005
Posted 14 January 2013 - 10:43 PM
I don't recommend this method, as the other end of the clamp will be pushing on the handbrake bracket and you'll end up bending it.
