How To Get Power Wire From Battery Through Bulkhead
3 replies to this topic
#1 malcolm159
malcolm159
    Newbie
  • Pip
  • 2 posts
  • Name: malcolm
  • Ford Model: fiesta titanium
  • Year: 2009
Posted 05 December 2012 - 04:51 PM
Hi, any one know how to get a wire through the bulkhead on a fiesta 2009 titainium r/h drive.I want to run a wire with fuse direct from the battery to inside the car to connect a radio up I,m a radio ham and need the power direct from the battery.I,ve a had a look and its seems the main wiring harness goes through the bulkhead behind the battery but cant see where it is inside the car even when taking out glovebox I think its behind the passenger airbag and don't really want to remove this.
Can any one help me ???
Thanks in advance.
Regards malcolm
#2 FOCA
FOCA
    Feet On The Table
  • 835 posts
  • Name: FOCA
  • Ford Model: Ford Mondeo
  • Year: Non
Posted 05 December 2012 - 05:20 PM
If you push a wire coat hanger (carefully) through the rubber grommet where the loom runs through the bulkhead and get a mate to wriggle it about while you look for it behind the glove compartment, (you may need a torch) you can tape the wire to the coat hanger then pull it through. its tricky and you may need a few tries and you may have to get right into the footwell to see
#3 malcolm159
malcolm159
    Newbie
  • Pip
  • 2 posts
  • Name: malcolm
  • Year: 2009
Posted 06 December 2012 - 10:14 AM
Hi thanks for info, had a look at that before including taking the glovebox out so have a big space to look in but I can't seem to see the end where the wiring comes into bulkhead the passenger airbag is in the way.Have you manged to do this on a fiesta with an passenger airbag fitted.
Thanks in advance
Regards Malcolm
#4 FOCA
FOCA
    Feet On The Table
  • 835 posts
  • Name: FOCA
  • Year: Non
Posted 06 December 2012 - 06:45 PM
I have not done this on a Fiesta, but on a Mondeo (with passenger airbag), there must be some way of doing it on yours, even if you have to drill a hole lower down (below the level of the airbag)
