Winter Fuel Consuption
6 replies to this topic
#1 KJO
KJO
    Newbie
  • Pip
  • 5 posts
  • Ford Model: Fiesta
Posted 05 December 2012 - 09:11 PM
I have a 97 1.3 Fiesta with an endura engine. All through the summer I was getting 54 mpg. However now winter has come the consumption has fallen to 40 mpg. Is it usual for the winter consumption to fall so drastically The journeys are just the same, a 20 mile commute which is mainly rural driving. Any suggestions as to why the fuel consumption has fallen so much?
#2 Marcr1
Marcr1
  • 802 posts
  • Name: Marc
  • Ford Model: Fiesta S1600
  • Year: 2012
Posted 08 December 2012 - 08:40 PM
Possibly your tyre pressures? put a few tanks of premium petrol in as well, will help to clear the system of any muck that may have accumulated
#3 EnglishElectric
EnglishElectric
    Newbie
  • Pip
  • 4 posts
  • Ford Model: 2008 focus Titanium
Posted 08 December 2012 - 11:33 PM
The colder air of the winter is more dense which means there's actually more of it entering the air box.
A simple carburetta would add more fuel to stop the engine running lean. I should think a modern engine management system would compensate for air temp/pressure and control the amount of air entering the manifold. I'm not an expert. My old focus had an induction kit. I had to make a sock for it to wear over the winter.
As Marcr1 said check your tyre pressures, they might be down a bit. Remember fuel is also more dense and heavier so if you always have a full tank you will be lugging more weight around.
Alastair
#4 Early-1800
Early-1800
  • 71 posts
  • Ford Model: Fiesta Titanium 1.6 tdci 3dr in Morello
Posted 09 December 2012 - 07:04 AM
Winter driving always takes a hit on MPG. Reasons I can think of are;
Colder engines are less efficient, thicker oil, petrol mixture running 'rich' for longer until engine warms up. Think this is the main culprit.
Engine running warming cabin whilst you scrap ice off windows.
All electrics running (heated screens, lights, blower etc) that are not used in summer adding extra load on engine
Weather wet and windy (although that sounds like this summer.....) causing more drag.
Tyre pressure drops a little increasing resistance.
I have a colleague with a BMW 320D who keeps detailed records of his MPG and it drops by a few mpg in winter. I mentioned that being a turbo intercooled Diesel the colder winter denser air should improve it abit but looks like the other things cancel it out.
#5 FOCA
FOCA
    Feet On The Table
  • 843 posts
  • Name: FOCA
  • Ford Model: Ford Mondeo
  • Year: Non
Posted 09 December 2012 - 01:30 PM
+1 absolutely, you can add the lower calorific value of winter diesel to that list, re- diesels
if you spend 15 minites letting your car tick over as you scrape the windscreen etc, you could have driven 10 miles in that time (at a 40mph avarage) - this adds up if you do this all through the winter, and its not going to help the overall MPG
#6 jeebowhite
jeebowhite
  • 4,304 posts
  • Name: James
  • Ford Model: Focus CMAX 1.6 CVT TDCI
  • Year: 2005
Posted 10 December 2012 - 01:42 PM
Agreed, although sometimes there is little difference between them, Summer and Winter have subtle differences that add up. To be honest, early 1800 summed it up quite nicely, temperature, thicker air, more air resistance, more drag, colder engine, and not all ECU's will compensate for the thicker air becuase it doesnt really detect it. If it does, it tends to overcompensate as well...
#7 1989jeffrey1989
1989jeffrey1989
  • 95 posts
  • Name: kieren
  • Ford Model: fiesta zetec
  • Year: 2012
Posted 10 December 2012 - 05:42 PM
The colder season has dropped my mpg down by 2 mpg /: lol
