Indicator Not Cancelling, What Else Can Be The Problem?
4 replies to this topic
#1 screamer
screamer
  • 119 posts
  • Ford Model: Fiesta 1.4 TDCi Titanium
Posted 06 December 2012 - 05:22 PM
My partners 2002 fiesta left turn indicator does not cancel, i've got another indicator stalk from ebay, replaced it, but it's the same
what else can look at replacing to try and fix this?
#2 PeanuckleJive
PeanuckleJive
  • 56 posts
  • Ford Model: Mondeo Estate 2.0 TDCi Zetec
Posted 06 December 2012 - 06:27 PM
Does it only happen in one direction or both?
Probably something in the clock spring mechanism that isn't turning it off I imagine
#3 Drummer
Drummer
    Newbie
  • Pip
  • 5 posts
  • Ford Model: Fiesta MkV
Posted 06 December 2012 - 07:19 PM
I have the same problem with the left signal not canceling. The right one does, but never the left. There's a difference in feel between left and right too, as if one direction needs moving mor than the other before it clicks, if that makes sense. Also, the flash seems a bit weird, as when you pull it all the way, it flickers, as if it's a loose connection. I wonder if our problems are similar in source.
#4 Matt93
Matt93
    Newbie
  • Pip
  • 5 posts
  • Ford Model: Fiesta Zetec 1.25 Ghia
  • Year: 1999
Posted 06 December 2012 - 07:50 PM
This happens on both of my indicators. Its not a problem cancelling them manually, but would be greatful to find a reason why :)
#5 screamer
screamer
  • 119 posts
Posted 06 December 2012 - 08:36 PM
only the one direction, left, i took out the stem, part number XS6T11K665CA, the wee white plastic bit that locates into the steering wheel, seems to have a bit of resistance when you put the indicator on one way, but not very much the other, it's the same on both stalks i have, coincidence??
