anthut Posted December 6, 2012 Share Posted December 6, 2012 I have a 2006 1.8 TDCI Ghia which I bought new. Two weeks ago the alarm was going off in the middle of the night , wipers going ,lights flashing and other strange things. The fault was diagnosed as the gem module and a new one was fitted. My local garage took it to a main dealer to set up and they said all was fine. All is fine apart from when I tested the alarm the indicators flashed but the siren does not go off. Today I took it back to the main dealer and was later informed that my car did not have a factory alarm fitted so all the times it had gone off were of course in my imagination. They looked in the behind the rear offside door pillar and there are wires and no horn. They checked three other Focus all newer models and they had the alarm in that place. The suggestion was I found another 06 Focus , set the alarm off and listen to where it is. My own thoughts are that the gem box is not set correctly but they wont have it. Can any one tell me where the siren is located Thanks Ant Quote Link to comment Share on other sites More sharing options...
NorthSussex Posted December 6, 2012 Share Posted December 6, 2012 Has your car been fitted with an after-market alarm? Quote Link to comment Share on other sites More sharing options...
anthut Posted December 6, 2012 Author Share Posted December 6, 2012 No - bog standard factory fit , Thanks Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 6, 2012 Share Posted December 6, 2012 On mine I believe the standard horn is the alarm horn. Quote Link to comment Share on other sites More sharing options...
anthut Posted December 6, 2012 Author Share Posted December 6, 2012 Mine makes a sound like a burglar/smoke alarm rather than a horn beep but I know what you mean. I did ask them to contact Ford to find out and they said they really need a wiring diagram , not something they give out with the service book though Thanks Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 6, 2012 Share Posted December 6, 2012 Strange. Mine's a 2007 and it's definitely the horn that sounds when my alarm goes off. Quote Link to comment Share on other sites More sharing options...
anthut Posted December 6, 2012 Author Share Posted December 6, 2012 If it would only work then of course I would know where it was , the car also has the surround alarm with a deactivation switch on the drivers door. I think this is where other models have a internal boot release but the Ghia has no such simple function apart from using the remote key. it is a mystery which could have a simple answer. The battery was disconnected for a couple of days to stop the alarm going off when it was awaiting the part. This may have a bearing on why it does not work now but I would have thought fitting the new electronic brainbox to the car would have sorted it. Quote Link to comment Share on other sites More sharing options...
Mike77 Posted December 7, 2012 Share Posted December 7, 2012 Strange. Mine's a 2007 and it's definitely the horn that sounds when my alarm goes off. Mine is a late 2006 and is definitely NOT the horn, more a high pitched beeping ? The plot thickens lol. Quote Link to comment Share on other sites More sharing options...
gforce Posted December 7, 2012 Share Posted December 7, 2012 I'm pretty sure that the alarm on my 55-plate Titanium is higher pitched than the standard horn also. Can investigate a bit further tomorrow if still need be, but won't get a chance until then. Out of interest, how long ago was everything back up and running? With the battery disconnected, some functions can take a while to kind of re-learn what they're supposed to do. Like one-touch opening of windows, but this can be re-programmed manually. Not sure if there's any similar manual way of 'teaching' the alarm how to work properly again. Quote Link to comment Share on other sites More sharing options...
Brigante Posted December 7, 2012 Share Posted December 7, 2012 I'm sure my alarm on my ghia just sounds like it's the horn going off It's not very loud either, can barely hear it from inside the house Quote Link to comment Share on other sites More sharing options...
anthut Posted December 7, 2012 Author Share Posted December 7, 2012 The alarm was going off just after midnight and I unlocked the car and put the key in the ignition to stop it, this continued for another hour so I disconnected the battery. The battery was re-connected at 5pm the next day to get it to my local garage. i think they disconnected it again as the part was not in stock with Ford. About 4 days later the new ECU was fitted. I did read somewhere on the net about manually re-setting the alarm. I think it said set the alarm, unlock with the key instead of the fob, put key in ignition, disconnect battery and re-connect and that should sort it. Anyone tried this. The alarm is a buzzer rather than the horn. Ant Quote Link to comment Share on other sites More sharing options...
talksy Posted December 9, 2012 Share Posted December 9, 2012 I believe mine is located in my boot. I have a standard focus, no modifications. I set it off by accident one day whilst in the car. Scared the life out of me and was definitely coming from boot area. Quote Link to comment Share on other sites More sharing options...
NorthSussex Posted December 9, 2012 Share Posted December 9, 2012 The alarm hooter on my previous Mondeo was in the boot behind the trim, passenger side, (well hidden). If it keeps sounding you can unplug it. It may be in the same location on the Focus. Quote Link to comment Share on other sites More sharing options...
anthut Posted December 9, 2012 Author Share Posted December 9, 2012 Thanks all , the garage is coming around to the fact that there is an alarm and perhaps the fuse has gone or not plugged in, in the new GEM. Ant Quote Link to comment Share on other sites More sharing options...
