Guide To Installing A Reverse Parking Camera
56 replies to this topic
#46 trikidy
trikidy
    The Great Pretender
  • New Member
  • 240 posts
  • Name: Reece
  • Ford Model: Fiesta Zetec S
  • Year: 2007
Posted 23 July 2013 - 03:58 PM
Cant find a camera that fits my car!
http://i.imgur.com/jUT1cS2.jpg
Have something to contribute?
#47 ktm2009
ktm2009
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Name: matt
  • Ford Model: focus
Posted 03 September 2013 - 08:21 PM
why cant i see any of your pics mate.could do with a hand
#48 stevegtuk
stevegtuk
    Stevegtuk
  • True Ford Enthusiast
  • 564 posts
  • Name: Steve
  • Ford Model: MONDEO
  • Year: 2006
Posted 04 September 2013 - 09:21 AM
try find the one that closest fits, preferably bigger than you need, then you can just trim it to fit.
#49 trikidy
trikidy
    The Great Pretender
  • New Member
  • 240 posts
  • Name: Reece
  • Year: 2007
Posted 04 September 2013 - 02:13 PM
UPDATE-
I removed the stock light and cut a whole just big enough for the camera I ordered, I then melted the plastic around it so it became one piece (also had to trim the camera)
http://www.ebay.co.u...984.m1439.l2649
I believe that is the one I ordered.
Anyway now my camera is all fitted :) for some reaso it wouldnt work on my head unit so i ordered a separate screen.
I have since got replies from sellers and I have been told the nearest fit to my car is this camera-
http://www.ebay.co.u...984.m1423.l2649
So for anyone with the same car as mine it might be easier to order this one and see how well it fits!
Thanks guys
#50 mikeol
mikeol
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Michael
  • Ford Model: Fiesta Mk 7
  • Year: 2013
Posted 03 March 2014 - 06:51 PM
Some good advice here but has anyone fitted a similar camera to a Fiesta Mk 7 (2013). I can't see a straightforward way of routing the wire from the hatch down to the reversing light. I can see I will have to remove the hatch trim to get to the wiring but getting behind the hatch metalwork to reach the rubber conduit looks too difficult. My camera setup uses a wireless system so I don't need to reach the front of the car with wires. Any advice appreciated.
#51 1ncredible
1ncredible
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Phil
  • Ford Model: Focus
  • Year: 2009
Posted 12 April 2014 - 05:29 PM
Does anyone have the pictures that they can email me please from this thread?
They're not coming up.
#52 Brigante
Brigante
    Resident Ranter
  • PipPipPipPipPip
  • 2,991 posts
  • Name: Charlie
  • Ford Model: Mondeo Titan X Sport 2.2 175BHP
Posted 18 April 2014 - 08:53 PM
Unfortunately my photos have been viewed too many times this month so my image hosting account has reached it's bandwidth allowance. The free bandwidth allowance won't reset till the 4th May so my photos will be down until then.
If anyone would like to make a paypal donation to get my photos back up in the guides they are more than welcome to.
#53 troy45
troy45
  • 1,301 posts
  • Name: Troy
  • Ford Model: Focus ST
Posted 28 July 2014 - 11:26 PM
My reversing camera arrived on Saturday - supposed to clip in to replace the number plate lamp on facelift but it didn't fit very well at all. I had to file various bits of it plus put a much larger chamfer on the body of the camera AND still do a bit of surgery on the finisher before I was happy with it   :huh:
Hoping it still works after all that.
Managed to see the earlier photos by right clicking and copying image url then pasting the link into Chrome (in IE you need to select Properties to see the url and copy it)  ;)
#54 troy45
troy45
  • 1,301 posts
  • Name: Troy
Posted 29 July 2014 - 12:01 AM
Was going to post this in the Sat Nav topic but my update is probably better with this topic
Am probably about 2/3 of the way through the camera installation on my facelift ST using the great information from the OP
I expected the camera to arrive before my new headunit so thought I would kick off getting the wiring work done. Not a great start though, the camera was a right pain to get fitted nicely into the finisher. It didn't sit flush, wouldn't lock in place and the camera fouled the finisher quite a bit too. Dremel and various hand-files needed to perform the required camera/tailgate finisher surgery :o
Work in progress shot here
The grommet for the finisher had a spare stub to use but there was no way the wiring with connectors and junction block would go through it so I had to cut the cable and rejoin it after I'd fed it through - then some faffing to try and seal the grommet and prevent any water ingress to the boot.
Then onto the wiring going to the reverse light and also the cable which needs to go to the head unit/display.
Different than some of the photos I've seen but my car had wiring on the lhs of the boot for the reverse light feed but the cable supplied was still too short, rough measuring showed it would get halfway round the tailgate but no further. But I was forewarned having read Brigante's guide and picked up some extra cable on Saturday. I managed finally to get the side trim off the tailgate so could access the existing wiring all the way round. Had always thought the pin which the parcel shelf string hooks onto would need removing but not so.
For the reverse light wiring I cut into it then used butt splices to rejoin along with a connector so I could disconnect it again if needed. The splices are really handy as you just double up the break out wires with the original wiring at one end and just crimp it up, join the other end back into the original circuit then give it a waft with heat gun and the heatshrink closes up plus releases a glue as well.
Then worked from the top of the boot to run the cables through from the tailgate. Was chuffed to find that the large connector on the long camera cable would go through the umbillical for the wiring, so no need to cut the cable and join it all up again :) I also pulled the push-pins, lhs roof trim and rear grab handle from the headliner to let me pull it down a little bit and route the cables round to come down the rear pillar as per the existing wiring .All went to plan and after the use of much electrical and cloth tape I ended up with all the tailgate end of things finished off.
Left some slack cable at the camera end of things just in case it's needed later.
Didn't get as far as terminating the wiring for the reverse light but that'll be simples now. Also decided to bring the camera wiring down the d-pillar to meet up with the main wiring, intention to run the cable along the floor instead of along the roof and down the A-pillar. Whether I come to regret that decision remains to be seen  :rolleyes: Course the cable isn't long enough now and I'm hoping that getting an extra 1m cable isn't too difficult.
Not got the headunit fitted yet, just after finally calling it a day a parcel man turned up with this  :D
As usual a straight forward job took me all day but wanted to make sure I did a proper neat job.
#55 Barry T
Barry T
  • Budding Enthusiast
  • 45 posts
  • Name: Anthony
  • Ford Model: Focus mk3 Titanium
  • Year: 2011
Posted 26 October 2014 - 07:54 AM
Hi All,
           Just fitted a reversing camera to my Ford Focus MK3. I am pleased with the camera and fold up monitor.
I have noticed that the number plate is not illuminated at night  the same as the original light fitting, also the camera projects out to far restricting the amount of light to about a third of the number plate..
I am concerned about being stopped at night by the police, Do these  replacement number plate light cameras conform to legal requirements ?. I would like to know just in case I end up with a ticket and points on my licence.
Out of curiosity does any one know the type of camera installed by ford in the mk3 focus, and where are they positioned.
Barry T
#56 Cozzter
Cozzter
    Newbie
  • Members via FB
  • Pip
  • 3 posts
  • Name: Corey
  • Ford Model: Focus RS
Posted 23 June 2015 - 11:20 PM
Great guide mate! I have a Ford Focus RS MK2, so I already have the camera installed. I was just wondering if you could help me out please. I am looking to put in a switch on the center console utilizing one of the blanking plates, so that I can manually turn on the camera whenever i like but NOT having the reverse light on at the same time. Obviously this would just be a gimmick and I thought it would be pretty cool to have this feature in. Any idea how I would go about doing this and where to attach the switch on the camera wiring? I have been looking everywhere online and I think you are the man to speak to:)
Any help would be much appreciated.
Corey
#57 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,220 posts
  • Name: James
  • Year: 2007
Posted 18 July 2015 - 07:24 PM
You would need to wire in the switch directly to a live circuit. Running a wire from the battery to the centre console then the switch, then run it back to the camera and feed. Basically taking a two point power intake to the camera, one feed from reverse, the other the switch.
Not what you're looking for?
