Heated Windscreen Washers!
10 replies to this topic
#1 b1g_dav3
b1g_dav3
  • 1,692 posts
  • Name: David
  • Year: 2013
Posted 10 December 2012 - 07:27 PM
Howdy folks, I was wondering has anybody managed to get their washers heated on the Fez (using Focus washer jets)?
I've seen looms on fleabay and wondered if it would plug in to anything on the Fiesta? Or would I need to cut and stick some wires? :P
Thanks.
#2 iNath
iNath
    Ford Traitor
  • Super Mod
  • 2,725 posts
  • Name: Nathan
Posted 10 December 2012 - 07:31 PM
There won't be any plug and play sockets as it was never an option for the Fiesta. Cut 'n' splice I'm afraid!
#3 b1g_dav3
b1g_dav3
  • 1,692 posts
  • Name: David
  • Year: 2013
Posted 10 December 2012 - 07:44 PM
Will probably get the loom then, and just splice that in, at £10 it's the price of wire and clips really.
#4 Hell_Bunny_sXe
Hell_Bunny_sXe
  • 556 posts
  • Name: Allan
  • Ford Model: Fiesta 1.4 TDCi Titanium
  • Year: 2009
Posted 10 December 2012 - 08:10 PM
Where would you splice into?
If you do this can you make a guide for us clods?
#5 sambooka
sambooka
    Sam Oglesby
  • 895 posts
  • Name: sam
  • Ford Model: mk7 fiesta tdci zetec s
  • Year: 2011
Posted 10 December 2012 - 08:18 PM
A guide would be handy am thinking of doing mine it's just where to start
#6 iNath
iNath
    Ford Traitor
  • Super Mod
  • 2,725 posts
  • Name: Nathan
Posted 10 December 2012 - 08:28 PM
Good question, I would assume the heated windscreen loom, no idea if it's correct voltage/amp though?
#7 b1g_dav3
b1g_dav3
  • 1,692 posts
  • Name: David
  • Year: 2013
Posted 10 December 2012 - 09:16 PM
All I know is on the Focus, they're linked up to the heated front screen, might see if the Focus is broken over the next day or so at work and see just how, probably the easiest way to start with.
#8 Magenta
Magenta
  • 427 posts
  • Name: Alan
  • Ford Model: Fiesta Mk7 Titanium 1.4 Auto - Marello
  • Year: 2009
Posted 11 December 2012 - 10:49 AM
Much easier way seems to be the idea that was detailed on this forum some time ago of simply cutting two circular pieces out of the bonnet insulation under the jet positions. This uses the heat from the engine at least at the jets. The writer tidied it up using desk cable tidies. I have not tried this in my Fiesta yet but I did it on my son's Mondeo and so far with the last few days sub zero temperatures he thinks it works.
Another idea I saw many years ago was to extend the plastic tubing and make a coil around the top hose, wrapping wide tape around the coil to retain it in place. Again I've not tried this as I think the water would freeze again by the time it reaches the jets. The above method seems a better idea.
#9 mikeo
mikeo
    Member
  • PipPip
  • 17 posts
  • Name: Michael
  • Ford Model: Fiesta zetec 1.25
Posted 11 December 2012 - 01:06 PM
Must admit that I have wondered about this myself.
For what I assume is a pretty small cost (relatively speaking) I consider this is a major omission on the Fiesta. You get heated rear/front screens and heated mirrors but no heated washer jets! Doesn't matter how strong you mix your screen wash... with exposed washer jets like this.... your ambient -5C (like this morning) is God only knows what with a 50/60+ mph wind hitting the jets!!
A much better design would be to recess the washer jets down by the windscreen wipers. I've had this on other cars and they don't freeze up half as much.
#10 Magenta
Magenta
  • 427 posts
  • Name: Alan
  • Year: 2009
Posted 12 December 2012 - 10:18 AM
I had electrically heated washer jets on a VW Passat i once owned - they still froze up.
#11 b1g_dav3
b1g_dav3
  • 1,692 posts
  • Name: David
  • Year: 2013
Posted 12 December 2012 - 11:32 AM
Yeah they freeze up, you need to have the screen on a little while before you get any effect. fitted all the wires and stuff which was pretty simple, just a case of finding various wires and such to get them hooked up. Not today though, busy busy :P
