Support the club!
Fiesta Mk4 Doing My Head In
10 replies to this topic
#1 mattcreate
mattcreate
    Newbie
  • Pip
  • 7 posts
  • Ford Model: ford fiesta MK4
Posted 11 December 2012 - 03:20 PM
Hi there,
I´ve got a 99 fiesta MK4, 1.3 petrol which has been at the "mechanics" for TWO MONTHS, now I´ve brought it home because it´s doing my head in,and I´m determined to fix it myself . Symptoms; poor idling,rough running, burning huge amounts of petrol and stinking the place out. Done so far; new throttle sensor,new idle air valve,replaced e.c.u, and watching useless mechanics scratch their heads for two months, any ideas?
Matt
#2 oilburner79
oilburner79
  • Members via Twitter
  • 109 posts
  • Name: darren
  • Ford Model: Focus Zetec Collection
  • Year: 2000
Posted 11 December 2012 - 04:45 PM
I'm presuming they checked the plugs,leads and coil pack?
#3 mattcreate
mattcreate
    Newbie
  • Pip
  • 7 posts
Posted 11 December 2012 - 05:42 PM
yes they did, tried an alternative coil pack and leads, checked the plugs are sparking,etc.
Thanks,matt
#4 mattcreate
mattcreate
    Newbie
  • Pip
  • 7 posts
Posted 11 December 2012 - 06:18 PM
By the way, the diagnostic computer insists the fault lies in the throttle sensor (replaced), and the engine will only start/run with the vacuum hose disconnected ( the small one behind the inlet manifold ).
#5 Steve
Steve
    Administrator
  • Admin
  • 4,842 posts
  • Ford Model: Kugy
Posted 11 December 2012 - 06:35 PM
Is it injection system or carbs?
#6 mattcreate
mattcreate
    Newbie
  • Pip
  • 7 posts
Posted 11 December 2012 - 06:40 PM
Sorry, it´s fuel injection, and it´s not the injectors because they tried a replacement injection ramp,no difference.
#7 DieselPig
DieselPig
  • 208 posts
  • Ford Model: Fiesta Zetec 1.6 TDCi
  • Year: 2011
Posted 11 December 2012 - 06:57 PM
Too much fuel may indicate the ecu sensors are faulty, have they replaced/tried the engine temp sensor/MAF/lambda sensor?
#8 mattcreate
mattcreate
    Newbie
  • Pip
  • 7 posts
Posted 11 December 2012 - 07:03 PM
Thanks Dieselpig, to be honest I don´t know,but I´ll certainly check up on that ,after I find out where those sensors are. That would explain why the diagnostic computer is giving confusing readings (?)
#9 sambooka
sambooka
    Sam Oglesby
  • 897 posts
  • Name: sam
  • Ford Model: mk7 fiesta tdci zetec s
  • Year: 2011
Posted 11 December 2012 - 09:07 PM
Thanks Dieselpig, to be honest I donŽt know,but IŽll certainly check up on that ,after I find out where those sensors are. That would explain why the diagnostic computer is giving confusing readings (?)
MAF mass air flow is located on the pipe that comes from the air box. Not sure on the other two
#10 DieselPig
DieselPig
  • 208 posts
  • Year: 2011
Posted 12 December 2012 - 05:33 PM
Lambda sensor is in the exhaust pipe near the catalytic converter, engine temp sensor will be near the thermostat in the engine block.
#11 mattcreate
mattcreate
    Newbie
  • Pip
  • 7 posts
Posted 12 December 2012 - 08:25 PM
Thanks, I´ve found the MAP sensor and the Lambda sensor, the IAT sensor I think needs some digging around under the air filter ( it´s not anywhere on the intake tube or manifold) and the engine temp sensor will need some digging around but now I know where it is ,or should be. I´ll let you know what I find, Cheers!
