Frozen Brakes
#1
Posted 12 December 2012 - 07:42 PM
this past few days here it is below 0 degrees, got into the car yesterday morning and again this morning the back brakes were frozen, the car would not move forward or backward, so i had to keep trying to get it to move as i was running late, so what i would like to know is there anything i can do to prevent this happening again and was it safe to force the car to move?
#2
Posted 12 December 2012 - 08:36 PM
#3
Posted 12 December 2012 - 08:43 PM
I haven't hard this issue with my Fiesta but on one of my past Fiats I had to make use of a big rubber mallet and give the drums a bit of a beating to free them up.
#4
Posted 13 December 2012 - 12:47 AM
Heat is the only option really, I have used boiling water once in the past when this happened to my girlfriends car.
#5
Posted 13 December 2012 - 01:17 AM
Run cold water over windows too, not boiling. I feel like smacking people's heads against the windows when they use boiling water, a bucket of cold water from the tap would work as well >.<
#6
Posted 13 December 2012 - 02:57 AM
Shouldn't use boiling water on a frozen part, you're up for micro-fractures, which I really wouldn't want on a breaking system that gets heated up >.<
No real difference in using hot water on the brakes IMO, think of when the brakes are hot and you drive through a puddle for example, they get quenched with cold water which is probably worse
#7
Posted 13 December 2012 - 09:19 AM
#8
Posted 13 December 2012 - 02:00 PM
#9
Posted 13 December 2012 - 10:58 PM
I never actually got the problem fixed though
Also going on from Magentas comment. My yaris used to have a built in feature where the car wouldn't start unless the clutch was fully pressed down.
Never forget I was on holiday and my dad wanted to take the car out. But couldn't get it to start! Not knowing about the clutch. Ringing up Toyota, having a go at them. They came out to inspect the car, realising what my dad wasn't doing... Awwwwwkwarddddddd
Latest Comments
More
