Posted 16 December 2012 - 02:25 PM
#17
Posted 16 December 2012 - 03:08 PM
#18
Posted 16 December 2012 - 03:17 PM
One live and one earth connection per light which will equate to four wires and four connectors.
#19
Posted 16 December 2012 - 03:22 PM
#20
Posted 16 December 2012 - 05:17 PM
#21
Posted 17 December 2012 - 07:30 PM
Connect one wire from each of the wires to the existing bulb holders without cutting the existing wires or else you will be sharing the voltage between two bulbs and they won't light up properly.
(yes Brigante I know I did that myself, before you rub it in.)
Lmao I've only just seen this.. What do you take me for
#22
Posted 17 December 2012 - 08:25 PM
Just going by experience.Lmao I've only just seen this.. What do you take me for
#23
Posted 18 December 2012 - 06:01 PM
#24
Posted 18 December 2012 - 07:09 PM
Hi lenny my piggyback fuse and bits came, so stick my light down and the were do I connect the negative and positive wires from the light to?
Connect the negative to an existing negative cable or earh point,
An earth point is a ring terminal like a washer that is bolted to the body of the car with earth cables running from it.
Then connect the positive from the lights to your choice of swith.
Then run a single positive feed from the switch to your piggy back fuse.
Followed by pluging the fuse in to an ignition live source or permanent live source.
Remove the existing fuse
Insert that fuse in to the piggyback plug along with a fuse for the light
Then plug piggyback in place of fuse.
#25
Posted 05 January 2013 - 08:40 PM
#26
Posted 05 January 2013 - 09:27 PM
#27
Posted 08 January 2013 - 08:48 AM
Also tagged with one or more of these keywords: Mods, interior, cheap, fiesta
