10 replies to this topic
#1
Posted 15 December 2012 - 01:10 AM
ok guys a friend of mine has a 57 plate ka and she has broken down and won't start up again all we get is a clucking noise and flickering from the dials any ideas on what this could be causing the problem
#2
Posted 15 December 2012 - 01:15 AM
flat battery
#3
Posted 15 December 2012 - 01:16 AM
Battery or alternator.
Try charging the battery first and see how you go from there.
#4
Posted 15 December 2012 - 01:20 AM
there is power in the car ie lights hazards wipers etc though
#5
Posted 15 December 2012 - 01:24 AM
yup but it takes alot more to turn an engine over
think of it like this, i can join 8x AA batteries to get 12v - i could power a radio, some lights etc but i wouldnt be able to start a car. the battery needs to be able to supply hundreds of amps to get the starter to turn the engine
#6
Posted 15 December 2012 - 11:41 AM
ah ok will try it and see what happens
#7
Posted 15 December 2012 - 03:12 PM
One other point. Most modern cars run silver calcide battery. These things seem to have the lifespan of a gnat! and they die very strangely, one day the car starts fine the next it won't then a few hours later it works again (sometimes for weeks) the only way to be realy sure is to find a decent garage (not a rip off merchant) and get them to do a drop test on the battery. One other strange issue is that you can't even retro fit an old style lead-acid battery as it won't charge!
Strange but true!
Phil
Strange but true!
Phil
#8
Posted 15 December 2012 - 05:56 PM
yeah her car started today got the battery checked and its fine so dunno what happened
#9
Posted 15 December 2012 - 11:38 PM
Now I would be looking for dirty/damaged wiring on starter motor or it could simply be that all the water we have had lately means the starter was simply sticking.
#10
Posted 16 December 2012 - 12:06 AM
noticed the copper wiring parts were black and also where can I go to generate a radio code as I know I need the serial number but note I'm not asking for it just looking to be pointed into the right direction for one as I know they are banned
#11
Posted 16 December 2012 - 12:08 AM
As your radio serial is most definitely a V code have a look on eBay, some there will post a code out for less than a fiver.
