Hi All,
I want to replace a automatic clutch with a manual clutch:
How do I get the auto clutch of the engine?
Cheers,
Jon
Ford Mondeo Tdci 2.0 Auto Clutch Replacement
Started by Jonny lad, Dec 16 2012 03:26 PM
mondeo clutch tdci automatic replacement torque converter
5 replies to this topic
#1
Posted 16 December 2012 - 03:26 PM
#2
Posted 16 December 2012 - 09:49 PM
i do not know if this can be done, do you mean removing the torque converter, then fitting a manual clutch with a clutch pedal and all the extras that go with it, it will be a major and expensive job.
#3
Posted 17 December 2012 - 12:23 AM
To change from auto to manual would mean, new flywheel, gearbox, clutch probably driveshafts, mountings etc. £££thousands worth of work. Why?
#4
Posted 17 December 2012 - 05:46 PM
Hi guys, I have a manual with a whole in the engine, so I bought a engine which has a auto clutch arrangement fitted, I will be using all the old parts from my damaged engine, I need to remove the clutch arrangement to fit my manual clutch etc etc, sorry for the lack of info.
The problem is getting the auto clutch off, it has a round shaft at the front with a flat spot on either side for a spanner etc, I'm not sure which direction to turn this to remove the unit? also I appreciate I will need to stop the ring gear turning etc.
Your help would be appreciated.
Jon
Jon
#5
Posted 17 December 2012 - 06:24 PM
Now I understand. You have an engine fitted with a torque converter, which you want to remove and replace with a flywheel for a manual. If the converers are still fitted like they were 20 years ago you will find 4 bolts on the BACK of the converter holding it to the adapter plate. When you've undone these you can lever off the converter and the adapter plate bolts will be uncovered. Apologies if this information is out of date, I've not dealt with autos for about 20 years!
#6
Posted 17 December 2012 - 07:53 PM
Cheers, had found a plastic cap that had hidden the bolts,
again thanks
Jon
again thanks
Jon
Also tagged with one or more of these keywords: mondeo, clutch, tdci, automatic, replacement, torque converter
Welcome to Ford Owners Club →
New Member Introductions →
New Member Northern IrelandStarted by paulzeetec, 17 Jun 2013 |
General Forums →
Audio & Electronics →
6000Cd Stereo Gone SilentStarted by Moonhogg, 14 Jun 2013 |
United Kingdom - General Ford Discussions by Model →
Ford Fiesta Club →
Mk4 Fiesta Zetec S Clutch Change. Quick Reply Please!Started by JacobOsborne, 10 Jun 2013 |
Ford Escort Club →
Mk6 Escort Gti ProblemsStarted by mophead105, 08 Jun 2013 |
Ford Fiesta Club →
Delivery DelaysStarted by Traquare, 07 Jun 2013 |
