Tyre Sizes
22 replies to this topic
#1 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,238 posts
  • Name: Daniel
  • Ford Model: Fiesta Mk6 1.3 Petrol
  • Year: 2003
Posted 23 December 2012 - 05:29 PM
Im getting a set of 16" alloys but they're not supplied with tyres. How do you find out what size tyres are right for the alloys/car?
http://www.fordparts...05627_c_246.htm
Thats the alloys im getting
#2 Mark M.K
Mark M.K
    Club Manager
  • Management
  • 1,382 posts
  • Ford Model: 1.6 Fiesta Titanium
Posted 23 December 2012 - 08:07 PM
At a guess, i'd say 195/45/16
#3 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,238 posts
  • Name: Daniel
  • Year: 2003
Posted 23 December 2012 - 08:08 PM
Is there a way to find out exactly? Or would I be best just taking one of the alloys to a tyre place and just letting them sort it out?
#4 Mark M.K
Mark M.K
    Club Manager
  • Management
  • 1,382 posts
Posted 23 December 2012 - 08:10 PM
I'm not 100% sure how to find out, but knowing Ford - it will be the same tyre size as the MK7 Fiesta with 16" alloys.
#5 TDCiST
TDCiST
  • 1,334 posts
  • Name: Dave
Posted 23 December 2012 - 08:12 PM
what are your current tyre size??
#6 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,238 posts
  • Name: Daniel
  • Year: 2003
Would it be the same tyre size thats quoted in the owners manual for 16" or would that be different because of the alloys?
#7 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,238 posts
  • Name: Daniel
  • Year: 2003
Posted 23 December 2012 - 08:13 PM
195/50/15
#8 TDCiST
TDCiST
  • 1,334 posts
  • Name: Dave
you have to keep your rolling radius the same (or extremely similar) so your speedo and odometer still work correctly..
If you post your current tyre size, i can work it out for you
#9 TDCiST
TDCiST
  • 1,334 posts
  • Name: Dave
Posted 23 December 2012 - 08:16 PM
http://www.alloywhee...Tyre_Calculator
using the above id say 195/45/16... the difference is minimal over the rolling radius... and not even 1mph difference at 70mph
is that a tyre size that is mentioned in the manual??
#10 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,238 posts
  • Name: Daniel
  • Year: 2003
Posted 23 December 2012 - 08:20 PM
Yeah it says 195/45/16 in book
#11 TDCiST
TDCiST
  • 1,334 posts
  • Name: Dave
sounds like a good plan then!! But get the tyre place to check
#12 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,238 posts
  • Name: Daniel
  • Year: 2003
Posted 23 December 2012 - 08:25 PM
Cheers :) im also getting it lowered aswell would I be better doing that before fitting the alloys?
#13 TDCiST
TDCiST
  • 1,334 posts
  • Name: Dave
Posted 23 December 2012 - 08:27 PM
doesnt really matter... at the same time would be good as youll already have the wheels off..
#14 DanGersFord
DanGersFord
    Dan The Gas Man
  • 2,238 posts
  • Name: Daniel
  • Year: 2003
Posted 23 December 2012 - 08:44 PM
Would I be better getting coilovers or just springs? And would I need new set of bushes? Its a petrol engine
#15 b1g_dav3
b1g_dav3
  • 1,693 posts
  • Name: David
  • Year: 2013
Posted 25 December 2012 - 11:50 PM
Better obviously coilovers, look at the price difference. Your stock shocks are designed to work with the stock springs, not with aftermarket ones, so they're not going to work as originally designed. Coilovers are designed to be used over a range of strengths and such.
That said, you'd be taking 30mm off the height, so it's not going to make a massive difference anyway or there'd be no market for springs.
Difference - £450 for a bottom end set of coil overs with only height adjustment, £100 for a similar quality set of lowering springs. Got the £350 extra and you'll be glad you got them, but it's a situation of how much money do you have to spend. I mean Ford use Eibach springs at around £180 which are what I'd go for if I went for just springs.
The way I see it, if ever you touch the suspension you should always change the bushes, unless just replacing like-for-like. Rubber bushes are junk especially when lowering. That said, again it's around £150 to replace the bushes.
