Fiesta 1.4 Tdci
steve's fiesta
hi
I recently purchased a fiesta 1.4 tdci 2006 64000 miles.
day after getting it home, noticed rather a lot of smoke from exhaust and not running smooth.
Changed fuel and air filters
helped with smoke problem.
on cruising, engine feels as if got hickups, a bit more throttle and it runs smooth untill cruising again.
done a 150 mile run, returned 42 mpg ??
any help or ideas welcome PLEASE
Sounds like the EGR valve is sticking, a fun job to dismantle and clean!
white smoke or grey smoke? it could be overfuelling as its diesel.
i would not describe it as white, greyish...
also the fact its bad on fuel mpg
would EGR valve cause the hickuping feeling ?
Yes, given the mileage the EGR valve will be choked with crap. My Mondeo had the same problem in fact most diesels with EGR will suffer the same problem.
Who even cleans those pesky things... Get a pipe to blank it. They're garbage and kill a few ponies.
you make it sound simple..
is it easy to blank it off to save future hassle ?
What about mot emissions ???
If its like the mondeo's it will depend if its a euro 3 or 4... if its a vacuum type as fitted on the euro 3 then you can just blank it and forget (although if its clogged up i would clean it out first)
but if its the euro 4 then it will be electronic and blanking it will bring up the eml light after a short while.
can anyone clarify if the fiesta will be the same for euro 3 and 4?
The 1.4 is a vacuum type so you could blank it off with no problems. Check there is a small bore rubber pipe connected to it.
i drove it as if i;d stolen it for about 5 miles, sure enough curled out smoke for first couple then seemed alot better.
i decided today to have a go at bypassing egr
filters all removed revealed multi plug with lots of wires from top part, no vacuum pipe ???
all back together, abandoned.
will tackle valve clean out when more time to spare.
thanks for all the help n tips so far
