soulman123 Posted December 31, 2012 Share Posted December 31, 2012 Whilst enjoying (not really) a drive in the rain as I parked I accidentally flicked the quick wipe which juddered and stooped 1/4 way on the screen if I use it again does the same till eventually its back in the home/park position. If I'm sad enough I can start it all again. Interestingly it works fine when used normally no juddering or stopping randomly at all which chucks my theory of a wiper linkage fault ? Do you think my wipers have had enough of being used on quick wipe or a non focus physcological fault ? ..forgot to add on wash wipe its fine aswell. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 31, 2012 Share Posted December 31, 2012 I'd get the intermittent relay checked. Quote Link to comment Share on other sites More sharing options...
soulman123 Posted January 1, 2013 Author Share Posted January 1, 2013 How do stoney :) I'll dig the haynes manual out, guessing this lives behind the glove box. I guess time to google how.to test a relay hehe. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 1, 2013 Share Posted January 1, 2013 To test a relay you apply 12v across the two low voltage pins and should hear the relay click. If you don't then the relay is shot. Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 1, 2013 Share Posted January 1, 2013 if the terminals are numbered, 85 and 86 are the trigger or coil. Quote Link to comment Share on other sites More sharing options...
soulman123 Posted January 1, 2013 Author Share Posted January 1, 2013 Thanks stoney and stef, I will give it a go. I have a 12v supply hiding somewhere. Quote Link to comment Share on other sites More sharing options...
cuke Posted January 2, 2013 Share Posted January 2, 2013 Hi, sounds like they are going into the service position.. Quote Link to comment Share on other sites More sharing options...
mjt Posted January 2, 2013 Share Posted January 2, 2013 I had this exact same fault. It was burned contacts in the relay. See this thread, in particular the last entry. Quote Link to comment Share on other sites More sharing options...
soulman123 Posted January 16, 2013 Author Share Posted January 16, 2013 mjt I will have a read of that now. with the extreme cold I have had no luck getting out there. The fault is intermittant, my local garage said its common and that the park motor is knackering .. his exact works. He said change the linkage eh wall another quote. I leave it as it is and check the relay first as the wipers still works as they should. Also ill have a read of the link mjt kindly gave. Quote Link to comment Share on other sites More sharing options...
soulman123 Posted January 16, 2013 Author Share Posted January 16, 2013 Out of interest is this classed as an MOT fault ? Quote Link to comment Share on other sites More sharing options...
soulman123 Posted January 16, 2013 Author Share Posted January 16, 2013 I had this exact same fault. It was burned contacts in the relay. See this thread, in particular the last entry. Very interesting read, looks like you've done battle with it. I bet this is my problem as others have mentioned. My concern us getting to this relay, is it hiding behind the glove box ? How to you drop it down/access it ? please say a few screws and it drops in to view lol Also where did you locate the relay for £5 sounds better than coughing up £24! thanks again for your post its been very interesting and helpful. *thumbs up* Quote Link to comment Share on other sites More sharing options...
Andy H Dibley Posted January 16, 2013 Share Posted January 16, 2013 Had this happen to me on my 08 Focus a few times, but always works normally 99% of the time so I don't worry about it. What triggered it off last time was leaving the wipers on full speed and driving in traffic. They do that thing of stop wiping when I stopped, I then went to creep forward, they started to wipe, I braked and so did they! It has also happened on the quick wipe setting. To make sure it wipes keep your finger held down on the stalk for the entire wipe. Quote Link to comment Share on other sites More sharing options...
Andy H Dibley Posted January 16, 2013 Share Posted January 16, 2013 Out of interest is this classed as an MOT fault ? Highly doubtful, at most I believe the inspector checks intermittent, normal speed and fast, add to that, the ability to clean the screen in a number of wipes. Quote Link to comment Share on other sites More sharing options...
soulman123 Posted March 5, 2014 Author Share Posted March 5, 2014 Right I'm back :) dry weather and time off amen. I've removed the relays and swapped r18 and r19 around as the back wipers parked home fine. The problem is there's is no change rear parks fine, front doesnt so I gues these means my relays are fine ? What could the fault be ? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted March 5, 2014 Share Posted March 5, 2014 If swapping the relays didn't produce a result I'd say wiper motor or wiring then. Quote Link to comment Share on other sites More sharing options...
soulman123 Posted March 5, 2014 Author Share Posted March 5, 2014 Noooo good by easy relay fix. *sob* Is the wiper motor hidden under the scuttle with the associated wiring ? When changing the motor does the whole linkage have to come out. Could it be the wiper switch itself at fault ? Wowser its £102 for the motor from gsf £176 from ford, wonder why a motor is so much. Popped in to ford parts the chap said the relay controls the park, I explained I swapped them and he said could be intermittant fault but the rear was faultless. Ordered the new wiper motor. Thanks for the post Clive. Quote Link to comment Share on other sites More sharing options...
soulman123 Posted March 6, 2014 Author Share Posted March 6, 2014 Found the Haynes in a box. Looks straight forward enough. Parts comes in tomorrow, weather permitting this weekend ill have a go. It only does it in quick wipe when you pull down and and when you push up. It's like it goes to sleep my like my energy saving lightbulbs at night when I need them to turn on! Will post my results if this weekend's tropical forecast happens. Quote Link to comment Share on other sites More sharing options...
