Interior Lighting Upgrade.
#16
Posted 06 January 2013 - 05:07 PM
#17
Posted 06 January 2013 - 06:53 PM
#18
Posted 07 January 2013 - 07:40 AM
#19
Posted 08 January 2013 - 10:35 AM
http://www.ebay.co.u...=item484bdfba1e
I have 2 of these fitted in the front light and 2 fitted in the rear and 1 in each of the footwell lights. They are nice and bright and give off a good spread of light.
#20
Posted 08 January 2013 - 06:18 PM
If its more light you are after have a look at the link below.
#21
Posted 08 January 2013 - 06:19 PM
#23
Posted 10 January 2013 - 08:05 PM
with the standard bulbs it did appear to be shining more on the front of the dash though and not where you'd actually want it.
first put in a festoon panel with 6 LEDs (http://www.ebay.co.u...=item4ab576b3c6). which was better because i slightly tinted it towards the interior more.
...but then remembered a 12 SMD panel (http://www.ebay.co.u...984.m1423.l2649) and my soldering iron started calling!!
its a tight fit in the courtesy light section, so i soldered the festoon adaptor directly into the panel with as little wire as possible.
here we go
with the LED festoon. you'll notice the light pointing forward and not really lighting the dash (tbh, it wasnt pitch black at that time, but you can still tell)
With the 12 SMD plate
Cheers
#24
Posted 10 January 2013 - 08:09 PM
#25
Posted 12 January 2013 - 08:41 AM
I searched Google and an astra(i think) forum was saying its just because leds run on tiny amps so it can go off what's left in the wires.
But if that's the case then why does it go properly off when the switch is fully off?
Any ideas? ..solder might have shifted to touch something else maybe?
Cheers
#26
Posted 12 January 2013 - 08:48 AM
#27
Posted 13 January 2013 - 09:31 PM
cheers
#28
Posted 14 January 2013 - 12:20 AM
#29
Posted 14 January 2013 - 12:47 AM
i dont really sit in my car so they not on long. if im actually looking arond ill probs use the white map lights anyway
..guess il use them till i kill them then get something better
#30
Posted 14 January 2013 - 01:24 AM
Latest Comments
More
