AdBlock Warning
Lesanne64
Fiesta - Water In Door Cavity
4 posts in this topic
I've got a 55 plate Fiesta and I've recently heard water swishing around inside the driver door panel. Anyone know how can I remove the panel to drain the water and is there any common way in which water could be getting in to the door cavity?
There's holes in the bottom that will be blocked with much, just stick a pen or stick through and clean them out.
The doors are designed to be wet, just make sure the drain holes are clear.
Perfect, thank you. Cleared the holes and bucket load came pouring out :(
