Ignition Source For Dash Cameras Using 12V Socket
4 replies to this topic
#1 graham1979
graham1979
    Member
  • PipPip
  • 25 posts
  • Ford Model: titanium
Posted 06 January 2013 - 08:16 PM
Hello guys and gals,
I am using two dash cameras which are plugged into a 12v splitter which is plugged into the 12v power outlet. From a previous post on here we established that the 12v is always set to "on" and this will drain the battery if I leave the cameras plugged in (already had one flat) but as I often forget to plug them in setting off it makes having pointless. I have had a few near misses, none of which my fault, but it is amazing how the other drivers will always give you a strange stare as in to say "WTF are you doing that was your fault".
IS is possible to connect the 12v spliter to some form of ignition lead in the car so that they turn on when I start the engine and turn off when I turn the engine off?
#2 TDCiST
TDCiST
  • 1,340 posts
  • Name: Dave
Posted 06 January 2013 - 09:01 PM
The switch live behind the radio for the front camera would be a good one...
As for the rear, you'd probably need to run something from the front...
It's that or wire in a new circuit fresh, which is a lot more difficult these days! You could connect the radio switch live to a relay, and use that to turn a permanent 12v feed on and off
#3 2011fiesta
2011fiesta
  • 1,528 posts
  • Name: Paul
  • Year: 2011
Posted 06 January 2013 - 09:13 PM
Nath had his connected directly to the ignition - think his dad wired it up.
I wouldn't know where to start, so my 12v splitter has an on/off button on the plug that sits in the 12v outlet socket - now just part of my routine, hand brake off, and flick the 12V switch on to power both front and rear cameras.
#4 mayo10uk
mayo10uk
  • Members via FB
  • 46 posts
  • Name: P
  • Ford Model: Fiesta Metal 132bhp
  • Year: 2012
Posted 07 January 2013 - 11:57 AM
Why not keep your set up and add something like this to it ?
http://www.ebay.co.u...=item3f0e528e1a
http://www.ebay.co.u...=item484ea531a6
#5 2011fiesta
2011fiesta
  • 1,528 posts
  • Name: Paul
  • Year: 2011
Posted 07 January 2013 - 04:53 PM
That's pretty much what's on the end of my splitter so I can flick the power on and off without pulling the whole thing out the socket.
Mine was from halfords, a four way splitter, LED-less though
