dezwez
Timing Belt
7 posts in this topic
Hi timing belt time witch one would you go with out of these Dayco
Gates
Quinton Hazell
SKF
FAI
Veco and how many miles are they good for longer the better. thanks in avd
I believe ford use gates i would personally only use gates fai i used on my vw and there tensioners were rubbish some would even shatter
hi thanks for reply gates it is then are these good for 100000
mile or should i renew sooner
Gates for me too
also i would never let a timing belt run for its full interval - there is no guarantee it will last
thanks guys
Always a good idea to change the idler pulley at the same time.
Idw buy the full kit the belts are good the tensioner always fails you should get the belt and tensioner as well as tensioner and cam bolts in the kit
