Passenger Side Engine Mount Question
MrG
Morning chaps - I still have a vibration/tremor at idle in my Focus Mk1 1.6 05 plate petrol beast; so far I've replaced PCV hose which was all squishy & PCV valve, VSS (as speedo kept dropping to zero) & the plugs & coil pack look ok.
Googling around, the passenger side engine mount seems to crop up as being a problem - firstly, is this the right part - http://www.fordparts...33019_c_597.htm
EDIT - just been thinking that the sites I was reading info about the passnger mount on were American - so I assume that their passenger side, would be our drivers side - so the hydraulic mount, not the one I've linked too above?
Secondly, is there any way of 'testing' the existing one?
Many thanks :)
Engine mount is filled with oil poo the airbox out and youll see it if its gone the engine will rock and there will be oil keaking from the mount ive found this is rarely the issue
