Polham Posted January 10, 2013 Share Posted January 10, 2013 I have an 06 diesel focus, 1.6 tdci. Recently the Powertrain warming light has appeared but has not affected performance until today when it went into limp home mode and lost power. Any ideas of the possible problem? Also tried to use the dash to get the fault code up but once it said no DTC's and the next time there was no codes, is this normal for a problem like this? Thanks Quote Link to comment Share on other sites More sharing options...
Mike77 Posted January 10, 2013 Share Posted January 10, 2013 It won't always show on the dash computer, the only thing to do is get it put on a diagnosis machine at a garage, or if anyone you know has a hand held one, you could try that first. But a garages equipment will have more info on. Quote Link to comment Share on other sites More sharing options...
Polham Posted January 10, 2013 Author Share Posted January 10, 2013 Cheers, was thinking of buying one of those machines of eBay, any experience with them and do they work? Quote Link to comment Share on other sites More sharing options...
Mike77 Posted January 10, 2013 Share Posted January 10, 2013 I have one, cost £80 and it picks up basic stuff, but my dads laptop (work) picks up WAY more info off it. Tried 3 hand held types when I had an engine management light on, and not 1 of them would show any faults, put it on the laptop and I was up and running again knowing what needed to be replaced. Get what you pay for I guess. Quote Link to comment Share on other sites More sharing options...
Polham Posted January 10, 2013 Author Share Posted January 10, 2013 What software and leads do you need for the laptop? Quote Link to comment Share on other sites More sharing options...
Mike77 Posted January 10, 2013 Share Posted January 10, 2013 What software and leads do you need for the laptop? Its not a case of software and leads, and just putting them onto a laptop, I was meaning that the garage equipment (which would have cost thousands) will always be more able to find faults than most handheld budget readers. My dads an RAC patrol, and they spend alot of money to have the latest software on their systems,, its not something most people could resonably afford. Taking it one step futher, going to FORD directly, they will have the most comprehensive system, and will pick up things that garages will miss. Top and bottom of it, cheap ones will pick up some stuff, failing that its a garage or breakdown rescue service, if their stuff cant find it,,,,,, its off to have your pants pulled down at FORDS. Quote Link to comment Share on other sites More sharing options...
Chelsea Blue Posted January 13, 2013 Share Posted January 13, 2013 I have an 06 diesel focus, 1.6 tdci. Recently the Powertrain warming light has appeared but has not affected performance until today when it went into limp home mode and lost power. Any ideas of the possible problem? Also tried to use the dash to get the fault code up but once it said no DTC's and the next time there was no codes, is this normal for a problem like this? Thanks Had the same problem, firstly the DPF Fluid was topped up and an attempted regeneration was performed without success. A new DPT was required at a cost of £1600.00 fitted. Told Ford to get stuffed and my local garage fitted an after market unit for less than half and all is well Quote Link to comment Share on other sites More sharing options...
martyntdci Posted January 13, 2013 Share Posted January 13, 2013 i had the eml light appear on mine, traced the code back with the torque app and came up powertrain malfunction...... but mine turned out to be a alternation and earthing problem..... just goes to show how wide the codes/meanings go... Quote Link to comment Share on other sites More sharing options...
