Hi folks
There's plenty of reference to this issue all over the net, but I can't quite find a definitive guide. The best one I've come across so far tells you how to get the old triple deck unit of a Mk6 Fiesta, but then suddenly all the advice seems to jump to which fascia/wiring adapters you need. I already have a double fascia adapter and a wiring bit that will in all probability work, but no one mentions the fact that after you've removed the triple-decker you seem to be left with a hole that has two plastic bars running across it.
Now, I haven't started digging into the dashboard on my daughters car yet, so maybe I'm barking up the wrong tree and all will become obvious should I take it apart, but it seems that there are two options: Hacksaw the blighters off (eek!) or get a whole new fascia. I've seen pictures of completed jobs so I know it's possible. I think I've also seen a picture of a replacement whole fascia that is sold to take a satnav that will do the job, but that could have been a dream.
To be honest I'll probably chicken out and get someone else to fit it, but I'd like to know how it's achieved. I'm sure the stupidity of this question will cause understandable hilarity, but humour me and if the winning advice comes from someone who lives near Beckenham I'll buy them a pint (I think I'm safe there).
Best wishes.
Replacing The Triple Deck Radio/cd Unit With An Aftermarket Player
Started by David P, Jan 12 2013 05:59 PM
6 replies to this topic
#1
Posted 12 January 2013 - 05:59 PM
#2
Posted 12 January 2013 - 06:37 PM
I did this and fitted the adaptor etc and you do have to hacksaw the bars off but I ended up buying the proper single din adaptor and fascia and its well worth it. It looks a million times better. You just need to be carefull with the heater/blower position controls as the can be quite tricky to get back into position when you're reasembling the center console. If you open the glove box theres screws you need to remove to get the fascia of and also theres a plastic panel under the steering wheel that you need to remove to get other screws.
Links the the proper bits if you want to do it properly: http://www.fordparts...22161_c_325.htm
http://www.fordparts...48612_c_325.htm
#3
Posted 12 January 2013 - 06:57 PM
If you need any help when your doing it feel free to ask ill post a couple of pictures of what it looks like when done properly when I get in the house. I painted all the fascia etc before I fittted it
#5
Posted 15 January 2013 - 12:06 PM
Well thank you Daniel.
All is now crystal clear and I've booked it into my local audio place who seemed knowledgeable enough. Hacksaw it is. And thank you for not insisting that I have that blue paint job.
Cheers!
Cheers!
#6
Posted 15 January 2013 - 12:20 PM
No need for the sarcasm I was just offering a reply to your question. Wont bother next time
#7
Posted 15 January 2013 - 12:31 PM
Oh dear Daniel
Which bit was I being sarcastic about? The blue paint job? Just picking up on your original light hearted comment about the same. Remember? The one where you put the little smiley face?
Your reply was genuinely helpful for which I thank you. Whether you bother or not in the future is up to you of course.
